Need help with an oil pressure problem - 600RR.net
post #1 of 13 (permalink) Old 08-11-2008, 07:00 PM Thread Starter
I got an 03 cbr 600rr....bike starts up and runs fine for about 5-10 seconds. After that the oil light kicks on and you can hear the engine run dry. I replaced the oil pump, checked out the strainer, and checked the pressure release valved. Anyone want to help me out here? What else can i check out?
robkc84 is offline
post #2 of 13 (permalink) Old 08-11-2008, 07:01 PM
i love juggggggggzzz
xxumattuxx's Avatar
Images: 11
you didnt mention checking that you have the correct amount of oil in it?
xxumattuxx is offline
post #3 of 13 (permalink) Old 08-11-2008, 07:04 PM Thread Starter
yea brand new oil change. I'm going to try a new filter. I just bought the bike and the bastards that sold it to me had it overfilled by a few quarts. I'm guessing to cover up this problem.
robkc84 is offline
post #4 of 13 (permalink) Old 08-11-2008, 07:04 PM Thread Starter
I already did replace the filter once when i did the oil change. Just wanted to clear that up.
robkc84 is offline
post #5 of 13 (permalink) Old 08-11-2008, 07:12 PM
xxumattuxx's Avatar
Images: 11
are you absolutely sure you have the right amount in because i had a similar problem, when there was not the correct amount of oil in my bike...
post #6 of 13 (permalink) Old 08-11-2008, 11:09 PM
Knightslugger
Posts: n/a
you've checked the switch and instrument-verified that you're not getting any pressure?
post #7 of 13 (permalink) Old 08-12-2008, 12:18 AM
Demented
Posts: n/a
Overfilled by a few quarts? Not possible from my understanding. You can't even get that much oil into the thing to be over by a few quarts.
How much did you put in with the new oil change?
post #8 of 13 (permalink) Old 08-12-2008, 09:05 AM Thread Starter
I'm going to do the pressure check today...i have to stop at the dealer and get the gauge and adapter..but how am i supposed to do the pressure check if i can't let the bike warm up?
I put 3.25 quarts of Rotella T 5w-40 when i did the oil change. I have a 5 quart pan that was completely empty....it overflowed.
robkc84 is offline
post #9 of 13 (permalink) Old 08-12-2008, 09:26 AM
Knightslugger
Posts: n/a
If you've got zero pressure at start up, chances are high you're going to have zero pressure at warm up. you don't need to let the bike warm to know there's pressure there.
See if you can rent one...
post #10 of 13 (permalink) Old 08-20-2008, 09:23 AM Thread Starter
Alright i did the oil pressure test....At startup i have a rough idle and it jumps back and forth from 0-10 psi....i did rev it up to 6k and i was getting about 40 psi...
robkc84 is offline
post #11 of 13 (permalink) Old 08-20-2008, 09:26 AM
Knightslugger
Posts: n/a
not right, way too low.
post #12 of 13 (permalink) Old 08-20-2008, 09:31 AM Thread Starter
yea it supposed to be like 70 @ 6k i believe?.....do you have any suggestions? Lower end? New engine?
robkc84 is offline
post #13 of 13 (permalink) Old 08-20-2008, 09:59 AM
Knightslugger
Posts: n/a
donno. It's loosing serious pressure somewhere. could be as simple as a ginormous air bubble somewhere that just wont budge. doubtful though.
you're going to have to tear into it to find the issue i think.
