HELP!! Fuel cutting out and overheating - 600RR.net
post #1 of 4 (permalink) Old 09-08-2008, 11:08 AM Thread Starter
Angry HELP!! Fuel cutting out and overheating
Ok first off thanks to anyone who helps with this or even takes the time to read my post. My bike, 2003 model, is having fuel issues. or what i am assuming is fuel issues. It will idle fine but under throttle my fuel is cutting out at about 6k rpms and my fi light is coming on. I am also having problems with overheating. not the typical is my bike running too hot overheating ive had an RR since 2005 and am used to the hotter than most temps. At cruising speeds i am getting into the fan kicking on temp ranges. I am running water wetter mix which i always have in the summer months and at times i would expect it to be running at 190 its running 220.. my fans are kicking on when supposed to but if i were to hit some traffic i would be screeewwed.. the bigger issue at hand is the fuel cutting out though. I am about to run the codes. I have a fresh oil change within and coolant flush and have checked all my fuses. Any help would be greatly greatly appreciated. Thanks!
jharless17 is offline
post #2 of 4 (permalink) Old 09-08-2008, 11:32 AM
Dr. GoFast's Avatar
is your gas tank rusty?
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #3 of 4 (permalink) Old 09-08-2008, 12:14 PM
Knightslugger
Posts: n/a
Check the Thermostat and make sure it's opening when it should. make sure you're not getting air in the system because of a warped head or cracked cylinder (Exhaust gases bleeding into the cooling system).
Also, check your battery connections (at the battery and to their destinations). Cut out at a certain RPM has often been the case of a loose power connector.
post #4 of 4 (permalink) Old 09-09-2008, 10:38 AM
bluechrome1981's Avatar
Cut out also could be a vaccuum leak... Check all your hoses off of your throttle bodies and such....
Opp Carbon Fiber Fairings, Carrozzeria Polished Wheels, Ohlins Rear Shock, Scotts Steering Stabilizer, Chrome Swing Arm, Stator Cover, Clutch Cover, Micron Full Race and Heat Wrapped, Power Commander, Velocity Stacks , Bmc Filter, Air Injection Controll valve deleted, Intergrated Tail Light, Flush Turn Signals.
bluechrome1981 is offline
