Cluster not working bike runs fine please help!! - 600RR.net
post #1 of 16 (permalink) Old 09-18-2008, 05:18 PM Thread Starter
ProjektSol's Avatar
Feedback Score: 8 reviews
Arrow Cluster not working bike runs fine please help!!
what possible ways can my cluster not turnon/show up
but my bike runs fine and everything?
could it be a fuse or something else?
i recently changed the subharness so it should work shouldnt?
please help i can be riding around like this =/
ProjektSol is offline
post #2 of 16 (permalink) Old 09-22-2008, 11:09 AM Thread Starter
ProjektSol's Avatar
someone please help!
post #3 of 16 (permalink) Old 09-22-2008, 11:12 AM
1ofakindRR's Avatar
You might want to check all the wire leading up to the cluster. Our bikes can't run without the tach. I tried trust me. Why did you change the sub harness anyways?
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
post #4 of 16 (permalink) Old 09-23-2008, 10:10 AM Thread Starter
ProjektSol's Avatar
because theres was a chip in the blue plug (corner) so i had it replace
but trust me the bike runs and everything just no display on the cluster!! wtf is going on...
post #5 of 16 (permalink) Old 09-23-2008, 10:14 AM
Knightslugger
Posts: n/a
no display, like NOTHING?
post #6 of 16 (permalink) Old 09-23-2008, 08:28 PM Thread Starter
ProjektSol's Avatar
ya no display
no mileage, mph that im going, or even the Green neutral light...
post #7 of 16 (permalink) Old 09-23-2008, 08:32 PM
Knightslugger
Posts: n/a
no tach, no signals NOTHING?
post #8 of 16 (permalink) Old 09-24-2008, 10:29 AM Thread Starter
ProjektSol's Avatar
YES!!!!
so can you help me or not?
post #9 of 16 (permalink) Old 09-24-2008, 10:38 AM
Knightslugger
Posts: n/a
you've checked that you're getting power to each lead from the connector in the back with a multimeter?
could be a shot dash.
post #10 of 16 (permalink) Old 09-24-2008, 11:02 AM
tripage's Avatar
Feedback Score: 91 reviews
Your bike will run just fine without the cluster hooked up. Check the main lead plugging into the back of the cluster. Make sure it's plugged all the way in. Then check all of your fuses. Brother has his trackbike with no cluster. Works just fine. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #11 of 16 (permalink) Old 09-25-2008, 11:57 AM Thread Starter
ProjektSol's Avatar
i will check that out!!
could there be any other possiblities?
do you think my signals would effect that cluster not showing up?
post #12 of 16 (permalink) Old 09-25-2008, 01:21 PM
Seems like the cluster itself is the problem....it is not out of the question.
Did it work prior to switching the harness?
If so, you can confirm if it is your new harness by plugging back in the old one.
z0sense is offline
post #13 of 16 (permalink) Old 09-26-2008, 08:38 PM
Originally Posted by ProjektSol View Post
ya no display
i just came on the forum to ask for help for the same problem, except that mine just happened out of no where when i got onto the freeway
the only thing that shows is the clock and the high beam.
stealthrapt0r is offline
post #14 of 16 (permalink) Old 09-27-2008, 02:22 PM
LonelyRR's Avatar
Images: 241
Did you check if your plate light is out?, if so.
Check all the 10A fuse in the mid left fairing.
LonelyRR is offline
post #15 of 16 (permalink) Old 09-27-2008, 08:16 PM
i read from another thread that it could be the 10A fuse. checked today and its toast. changed it and everything works now.
thanks!
post #16 of 16 (permalink) Old 09-27-2008, 09:32 PM Thread Starter
ProjektSol's Avatar
i will check it asap thanks everyone!!
