Loss of power ( Loose battery connection ) - 600RR.net
post #1 of 11 (permalink) Old 12-25-2008, 08:43 PM Thread Starter
BOTM 07/09
Metallica's Avatar
Feedback Score: 35 reviews
Decided to go out for a short ride tonight. Let the bike warm up to about 170 degrees and left. About 10 minutes in to it the bike just shuts off and the oil light comes on. I pull over, put it in neutral and she starts up just fine. The RPM'S were around 5-6k if I'm not mistaken. So I continue on and about 2 minutes laer the same problem, bike dies, the needle doesnt hit the red line when this happens btw. Turns over fine and proceed home, but happens again when I'm a block away from my home.
Just some quick info here: It's an 03 with roughly 7,700 miles. Havent taken her out for a few weeks because of the cold but did install rizoma rear turn signals a few days ago. The bike idles fine and my fuel gauge shows half a tank. What can be the problem? No error codes flash btw. Thanks in advance!
Originally Posted by sincalirider View Post
interesting........
Bahaha, a scalp massage usually ends with a happy ending.
Besides, you have the best girl any guy can get, an RR in the garage.
Metallica is offline
post #2 of 11 (permalink) Old 12-25-2008, 08:47 PM
Demented
Posts: n/a
How cold was it?
All I can think of is it either being far too cold to ride, or there is a loose connection somewhere since it's happening at the same RPM.
post #3 of 11 (permalink) Old 12-25-2008, 08:50 PM Thread Starter
BOTM 07/09
Metallica's Avatar
38 degrees, this just occurred in the past half hour. Also took the battery out to charge it after i installed the turn signals.
interesting........
post #4 of 11 (permalink) Old 12-25-2008, 08:51 PM
dcope17's Avatar
I'd check your connections. If you recently wired something, did you unhook your battery?
dcope17 is offline
post #5 of 11 (permalink) Old 12-25-2008, 08:51 PM Thread Starter
BOTM 07/09
Metallica's Avatar
Also, i would get her past 6k with no problem before and after this issue occurred.
interesting........
post #6 of 11 (permalink) Old 12-25-2008, 08:52 PM
dcope17's Avatar
I guess so. Tighten your battery.
dcope17 is offline
post #7 of 11 (permalink) Old 12-25-2008, 08:53 PM Thread Starter
BOTM 07/09
Metallica's Avatar
Unhooked the battery after i installed the turn signals and put her on the battery tender.
interesting........
post #8 of 11 (permalink) Old 12-25-2008, 08:53 PM
Demented
Posts: n/a
Definitely seems like a loose battery connection.
post #9 of 11 (permalink) Old 12-25-2008, 08:55 PM Thread Starter
BOTM 07/09
Metallica's Avatar
Thanks for the reply's so far! I'll check the battery connections right now.
interesting........
post #10 of 11 (permalink) Old 12-25-2008, 10:07 PM Thread Starter
BOTM 07/09
Metallica's Avatar
The negative connection was barely touching the battery. My own fault though, seeing how I hooked the battery up at 5 am while on 4 hours of sleep :icon_lol:
Hit the starter and she fired right up, revved it up to 14k and no issues whatsoever. Battery connections are nice and tight, thanks again everyone! The help/tips we're MUCH appreciated
interesting........
post #11 of 11 (permalink) Old 12-26-2008, 03:30 AM Thread Starter
BOTM 07/09
Metallica's Avatar
Took her out for a nice 2 hour ride. No issues to report
interesting........
Closed Thread
You may post new threads
You may post replies
