Turn Signal issue - I'm stumped - 600RR.net
post #1 of 9 (permalink) Old 01-09-2009, 04:35 PM Thread Starter
Stevo600rr's Avatar
So I've done a lot of searching and it seems many people have weird issues with their turn signals. But unfortunatly I have not found one that was they shade of gray that is my issue.
So here goes...
A few weeks ago I installed a flasher relay. My turn signals all worked just fine. I went on a 3 week vacation and I come back and here is where it gets strange.
My front turn signals flash properly. But my back turn signals stay on when I turn them on with a very slight flash. The timing seems right for the turn signals. But they dont shut off like they are supposed to, they just dim a little bit when they are supposed to turn off.
So...Im reading that a common issue may be that its grounding out, although I dont think thats the case.
We did have torrential down pours for a while during the period of my trip, so could humidity be a cause?
Should I be looking at the relay? I mean the timing is perfect, just the back lights staying on with the faint pulse of the "flash".
Beats me
Stevo600rr is offline
post #2 of 9 (permalink) Old 01-09-2009, 04:44 PM
tripage's Avatar
Feedback Score: 91 reviews
How did you wire up the turn signals? Water can do some amazing things since it's a conductor. Solder, Heat shrink is the best way to wire in connections. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 9 (permalink) Old 01-09-2009, 06:44 PM Thread Starter
Stevo600rr's Avatar
Well, I used electrical tape. I tightly wove it around all the length of the wire. My electrical jobs have never given me issues before. But I have also noticed that my high beam selector for my headlights is twitchy now. It takes a few flicks to get the high beam to come on. Seems like water is the issue to me.
post #4 of 9 (permalink) Old 01-09-2009, 07:07 PM
tripage's Avatar
I would check all the connections that you have done. Would guess a short that is your problem. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #5 of 9 (permalink) Old 01-13-2009, 07:51 PM
Has this been resolved? I have the same issue, could be a ground, but I can't seem to find where it's grounding out. I think my battery just doesn't have the juice to run the rear CA Integrated Tail.
Protons up front flash normal, rear flickers.
2006 CBR600RR
2003 BMW X5 3.0
2000 A4 1.8T
mnemonic is offline
post #6 of 9 (permalink) Old 01-13-2009, 08:43 PM
tripage's Avatar
If you do not have resistors installed then the signals can flash so fast they appear to not work.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #7 of 9 (permalink) Old 01-13-2009, 08:54 PM
My current setup is:
Protons up front
CA Tail
CustomLed Flasher Relay into harness.
Bike off, Protons blink at correct speed. CA dim and fast flash
Bike running, Protons fast, CA blinks correctly.
2006 CBR600RR
2003 BMW X5 3.0
2000 A4 1.8T
mnemonic is offline
post #8 of 9 (permalink) Old 01-13-2009, 09:43 PM
tripage's Avatar
Battery???? Have trouble starting the bike? Would keep an eye on it. Sounds like your battery is draining. Led's will show the slightest bit of power drop. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #9 of 9 (permalink) Old 01-13-2009, 09:47 PM
I'll have it checked tomorrow and will respond. Bike starts ok, after being on a charger overnight.
2006 CBR600RR
2003 BMW X5 3.0
2000 A4 1.8T
mnemonic is offline
