Headlights not coming on... HELP - 600RR.net
post #1 of 13 (permalink) Old 01-27-2009, 11:47 PM Thread Starter
WTF? My headlights just stopped working out of nowhere, one second the low beam was on, the next neither worked! HELP!
Jcochran is offline
post #2 of 13 (permalink) Old 01-28-2009, 12:01 AM
dcope17's Avatar
If neither work... most likely it is that start button. It turns off the lights (both high and low beams) while starting the motor. I think that switch is the only circuit that the high and low beams have in common.
dcope17 is offline
post #3 of 13 (permalink) Old 01-28-2009, 12:02 AM Thread Starter
edit: nvm i got it right after i asked >.>
Jcochran is offline
post #4 of 13 (permalink) Old 01-28-2009, 12:06 AM
dcope17's Avatar
Well. since it is not working... you can take it apart and see if there is something visibly wrong with it. Do you have a volt meter? If so... then what year is the bike? I have a wiring diagram and can look at what wires you can check.
dcope17 is offline
post #5 of 13 (permalink) Old 01-28-2009, 12:08 AM
3L3C7R0's Avatar
Images: 13
lol, wtf? that's your first asumption? my advice would be check your fuses...
3L3C7R0 is offline
post #6 of 13 (permalink) Old 01-28-2009, 12:17 AM
dcope17's Avatar
Seperate fuses fot the high and low beams... There have been several cases of the start button messing up on this forum... I think the odds are greater of a bad switch than 2 fuses kind of working then not working at all later.
dcope17 is offline
post #7 of 13 (permalink) Old 01-28-2009, 12:19 AM
dcope17's Avatar
correction... one fuse but I have never had a fuse sometimes work then sometimes not.
dcope17 is offline
post #8 of 13 (permalink) Old 01-28-2009, 12:21 AM
Demented
Posts: n/a
Both the high and low beam are on the same fuse/circuit.
They're on a 20A.
My guess, the headlight connections are loose.
post #9 of 13 (permalink) Old 01-28-2009, 12:23 AM
dcope17's Avatar
$5 Starter button...any takers?
dcope17 is offline
post #10 of 13 (permalink) Old 01-28-2009, 09:20 AM Thread Starter
You won. I went down, checked the fuse, even switched it out to be safe. check the wires, everything tightly secured. hit the starter button and wa-la i can seeeee.
haha thanks guys!
Jcochran is offline
post #11 of 13 (permalink) Old 01-28-2009, 11:59 AM
dcope17's Avatar
Wohoo Pay up everyone.
dcope17 is offline
post #12 of 13 (permalink) Old 01-30-2009, 10:40 AM
shiftn3rdon1's Avatar
The main problem for the headlights not working is usually ALWAYS the kill switch. You gotta get it fixed. If you just hit the kill switch, and the lights turned on, then you just completed the circuit in there. You need to take it apart and re-solder the tab that it wont happen again
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #13 of 13 (permalink) Old 02-02-2009, 11:59 AM
R3DS2K's Avatar
Feedback Score: 6 reviews
any write ups on this repair?
R3DS2K is offline
