Help, '03 600rr no lights, crank but wont start - 600RR.net
post #1 of 12 (permalink) Old 01-30-2009, 08:59 AM Thread Starter
ok
Bike stopped running about two months ago out of no where, and i fooled with it a couple times trying to see what the deal was. All fuses are good, replaced the battery.
Mods are Led undertail, fender eliminator kit, jardine slip on.
So heres the problem:
Headlights are off when the key is turned,
Cant hear ther fuel pump,
Tailight lights up half yellow halr red.
Bike turns over but wont crank.
The only problem it has that i know of is the right turn signal bulb is out, appart from that it has frsh gas, fresh oil, new battery, good fuses.
PLEASE HELP!!!!! Cant really afford to take it to the stealership, and i have a guy who wants to buy it today so i can put a down payment on a '09!
lex_rr is offline
post #2 of 12 (permalink) Old 01-30-2009, 09:15 AM
jsteckelberg's Avatar
Check this out, I don't know if it's the same symptoms, but it's an idea http://www.1000rr.net/forums/showthr...t=57844&page=2
jsteckelberg is offline
post #3 of 12 (permalink) Old 01-30-2009, 09:30 AM Thread Starter
worth giving a try, but i still dont understand how it affects the tailight/headlight/ dn ignition...
lex_rr is offline
post #4 of 12 (permalink) Old 01-30-2009, 12:59 PM Thread Starter
Also I forgot to add, tach comes on normal, but dosent light up
Anyone know if there are any fuses im forgeting about? I know under the tank on the left and under the seat, someone had mentioned somthing to me about under the tach?
lex_rr is offline
post #5 of 12 (permalink) Old 01-30-2009, 02:51 PM
Def. a Fuse.
Whenever lights are out, that means a fuse is blown.
Have you checked all the fuses, PULLED THEM OUT, and looked at them.
HardRacing is offline
post #6 of 12 (permalink) Old 01-30-2009, 04:41 PM Thread Starter
yep, pulled all the fuses, visual inspected and they all seemed fine, unless theres sme I don't know about. I know about the ones under the seat and under the left fairing. Are there any I'm missing?
lex_rr is offline
post #7 of 12 (permalink) Old 01-31-2009, 04:19 PM Thread Starter
k.... just realized the clutch is out.. Could this be the cause?
lex_rr is offline
post #8 of 12 (permalink) Old 02-02-2009, 09:45 AM Thread Starter
still have no idea bump
lex_rr is offline
post #9 of 12 (permalink) Old 02-03-2009, 12:10 PM
dcope17's Avatar
Your bike has a lot of problems. I don't know what you mean by the clutch being "out" but everything else seems electrical. Lights on half yellow/ half red? Something's wrong with the wiring. If you're not much of a wiring person or just don't want to track everything down... I'd just get a new wiring harness and start over. And fix the clutch thing.
dcope17 is offline
post #10 of 12 (permalink) Old 02-04-2009, 06:08 PM Thread Starter
anyone know where i can find a wiring diagram?
lex_rr is offline
post #11 of 12 (permalink) Old 02-04-2009, 09:59 PM
dcope17's Avatar
www.helminc.com has the service manuals. $60 but well worth it.
dcope17 is offline
post #12 of 12 (permalink) Old 03-01-2009, 06:11 PM Thread Starter
Bump
Bikes in pieces,and checked a few things with a voltage meter. No power is going to the fuel pump. Tried both with the bas on and with the bas bypassed.... Any new ideas guys?
lex_rr is offline
