03 radiator fan stays on and drains battery - 600RR.net
post #1 of 27 (permalink) Old 02-01-2009, 08:50 PM Thread Starter
So yeah this started last night i guess after i was riding for a couple hours. my homie said my bike was makin funny noises. So when i went to start the bike today it wouldnt start. Now heres where it happens. I have that self jump start thingy so when u connect the cables u can turn it on or off thing. yeah watever ok so when i turn it on the fan just starts up when theres no key in the ignition. so im like okaaaaaaaaaaay. i put the key start it up and ride it for like 10 minutes. then when i turn the bike off the fan stays on and within about 30 seconds of watchin the fan stay on i try to start the bike and its died... So if u can help that would be sicc thanx!
Nikka_De is offline
post #2 of 27 (permalink) Old 02-01-2009, 08:58 PM
shotgun713's Avatar
first things first make sure the previoius owner did not directly wire the fan to the battery or anything
also more infro about the bike and stuff would be great
"They Say At 100MPH Water Feels Like Concrete, Just Imagine What Concrete Feels Like At 100mph" - Nicky Hayden
Originally Posted by powermoose1 View Post
Plus, 200 seems low, you might just get Demented!
shotgun713 is offline
post #3 of 27 (permalink) Old 02-01-2009, 09:05 PM Thread Starter
well i mean i really dont think he did because it never did this b4. and ive riden the bike plenty of times. the bike has like than 4000 on it. he bought a new battery b4 he sold it to me.
what more would u like to knoe?
Nikka_De is offline
post #4 of 27 (permalink) Old 02-01-2009, 09:11 PM
shotgun713's Avatar
try to maybe change out the fan relay check all the wiring
post #5 of 27 (permalink) Old 02-01-2009, 09:16 PM Thread Starter
where would that be located?
Nikka_De is offline
post #6 of 27 (permalink) Old 02-01-2009, 09:23 PM
shotgun713's Avatar
i wish i can help u with that i have no idea on that year hell i ride a 05zx10r now just love this forum so im still here
but do a quick search on the relay location try swapping it with another relay see if that helps if not i would start tracing back from the fan into the harness for the cause of the problem
post #7 of 27 (permalink) Old 02-01-2009, 09:58 PM Thread Starter
ok i will thanx for the start thou.
Nikka_De is offline
post #8 of 27 (permalink) Old 02-01-2009, 11:02 PM Thread Starter
I Need Help Still! :(
Nikka_De is offline
post #9 of 27 (permalink) Old 02-01-2009, 11:08 PM
dcope17's Avatar
'03-'06 the relay is attached to the ram air tube on the left side. I can't remember which one. I can look it up though. '07 and up... it's under the seat. It sounds like the relay to me too. Probably just stuck in the on position. I don't think they're too expensive to replace.
dcope17 is offline
post #10 of 27 (permalink) Old 02-01-2009, 11:10 PM
dcope17's Avatar
'07 and up... fan relay is the front left one.
dcope17 is offline
post #11 of 27 (permalink) Old 02-01-2009, 11:10 PM
dcope17's Avatar
Sorry. you said '03 give me a minute.
dcope17 is offline
post #12 of 27 (permalink) Old 02-01-2009, 11:12 PM
dcope17's Avatar
there are 3 relays in line on the ram air tube... it's the middle one.
dcope17 is offline
post #13 of 27 (permalink) Old 02-01-2009, 11:28 PM Thread Starter
thank U !!!! so its sounds like the relay then?
Nikka_De is offline
post #14 of 27 (permalink) Old 02-01-2009, 11:37 PM
dcope17's Avatar
Yes.. I think it is. I just checked the wiring diagram and there is always power to the fan relay and the ECU controls when it turns on or off. So if the relay is stuck... it looks like even turning off the key will not even stop the fan. If that's what's happening then def... the relay.
dcope17 is offline
post #15 of 27 (permalink) Old 02-01-2009, 11:49 PM Thread Starter
yes sir it stays on thank u thank u!!!! but i just tried looking for one to buy i cant seem to find it. i find like main relays and turn signal relays but no r. fan relays... BUT THANK U! i really appreciate it. Im new to this whole bike scene. its like comin from cars to here u have to learn everything all over again.
Nikka_De is offline
post #16 of 27 (permalink) Old 02-01-2009, 11:56 PM
dcope17's Avatar
All 3 realys are the same. Part # 38380-MN5-003
If you just want to try it... switch out the relay with one of the others. You won't be able to start the bike w/o the other 2 relays but you can hook up the battery and see if the fan stays off.
dcope17 is offline
post #17 of 27 (permalink) Old 02-02-2009, 01:40 AM
shotgun713's Avatar
^^^ exactly what i do to start with before buying anything make sure its the problem first b4 u go out buy anything
post #18 of 27 (permalink) Old 02-02-2009, 03:28 AM Thread Starter
WOrd. do that first thing when i wake up thanx guys
Nikka_De is offline
post #19 of 27 (permalink) Old 02-02-2009, 07:19 PM Thread Starter
well idk wat this means but today i wanted to see if the fan would stay on if i charged the battery. so the fan doesnt do it woo hoo but the battery is charging so i let it charge awhile and start it up woo hoo. and it warms up and the fan turns on at about where it suppose to woo hoo but when i take the charger off the battery the bike starts to idle then dies... could that be that same problem?
Nikka_De is offline
post #20 of 27 (permalink) Old 02-02-2009, 09:25 PM Thread Starter
any1 have a clue?
Nikka_De is offline
post #21 of 27 (permalink) Old 02-02-2009, 09:34 PM
dcope17's Avatar
could be a number of problems. Your battery could be shot. Draining a battery completely dead several times will ruin it.
If your battery is shot then the bike runs off of the charging system. ( you still need a battery in the bike though) At idle speed the charging system doesn't produce a lot of power. I'm just guessing here but with the headlight, and fan running... it may not produce enough power to run everything.
Do you have a volt meter? If so... charge your battery and start the bike. (your battery might be good enough to start the bike) With the seat off... put the volt meter on the bat and chack the voltage. Let the bike warm up enough to turn the fan on and when it comes on... check the voltage again. If it drops less than 12v... I'd say the bat is shot.
dcope17 is offline
post #22 of 27 (permalink) Old 02-02-2009, 10:09 PM Thread Starter
but the battery is new...
Nikka_De is offline
post #23 of 27 (permalink) Old 02-02-2009, 10:19 PM
shotgun713's Avatar
if u take out the battery u can go to a local Auto Zone and have them load test the battery to make sure its still good its also free at Auto Zone
if the battery passes after you fully charge it then i would say check the fan relay make sure its good b/c the vibration could of caused to get stuck on
and kill ylour battery
post #24 of 27 (permalink) Old 02-02-2009, 10:23 PM
dcope17's Avatar
If the bat is good then it would be the charging system. I would check the bat first cause it is easier to check and is more likely to be bad since it has been drained completely.
If your bat has a full 100% charge and the bike dies when the fan kicks on... then your battery is not working correctly.
dcope17 is offline
post #25 of 27 (permalink) Old 02-02-2009, 10:24 PM Thread Starter
ok will do. cant do right now not home. but i will.
Nikka_De is offline
post #26 of 27 (permalink) Old 02-02-2009, 11:04 PM
dcope17's Avatar
let us know.
dcope17 is offline
post #27 of 27 (permalink) Old 02-13-2009, 07:18 PM Thread Starter
well i juss did it after like a week or two now lol. and it was the relay but i fried the battery using a car battery charger! LOL so i got another new battery. 2nd one within a month LOL. but hey i didnt knoe but now i do. Learn from mistakes! lol thanx to u guys for the help!!!
Nikka_De is offline
You may post new threads
You may post replies
