LED Signals HELP - 600RR.net
post #1 of 9 (permalink) Old 02-02-2009, 07:31 PM Thread Starter
LED Signals HELP
I have already purchased and installed a set of HotBodies flushmounts up front and just installed Shock Racing mini's in the rear. The front signals worked with the stock rear signals but after testing it with the rear LED signals they stay Solid (both front and rear signals) ive read a few posts and im hoping all i need are some resistors. But I dont know what kind (size?) of resistors I need. Could someone point me in the right direction?
RedRider89 is offline
post #2 of 9 (permalink) Old 02-02-2009, 07:36 PM
SchaadeS's Avatar
I dont know what size resistors, but that is what you need.
-Shelby
https://www.600rr.net/vb/showthread.php?t=124351
D3 Grips, O'Grady Paint, Powder coated everything, Custom LED switching, Tripage Third Eye, Custom LED Gauge Cluster, 6000K HID's, Integrated Mirrors with Signals, Integrated Signal/Brake light, Driven Sprocket Kit -1/+2, EK Chain 520 Pitch, PC3, Quickshift kit, Multi mapping touch screen, Block Off Plates, BCM Air Filter, DIY Short stack Air Mod, Speedohealer, Galfer Stainless Steel Brake lines, 450R mod, Yoshi pipe, Arrow Headers.
SchaadeS is offline
post #3 of 9 (permalink) Old 02-02-2009, 09:13 PM Thread Starter
I was hoping that was all I needed. How do I go about finding out what resistors I need though?
post #4 of 9 (permalink) Old 02-03-2009, 01:02 PM
go get them at radio shack it should be the same size as the tail light with signals I'll check mine when I get home to try to help
02blueR6 is offline
post #5 of 9 (permalink) Old 02-03-2009, 01:41 PM
tripage's Avatar
Feedback Score: 91 reviews
What year bike do you have? Plug n play option if you have 07-09. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #6 of 9 (permalink) Old 02-03-2009, 03:41 PM
dcope17's Avatar
I think you need 5 ohms. Radio shack has 10 ohm 10 watt resistors ( little square ceramic coated things. Put 2 of those in parallel to get the 5 ohms. And you'll need a pair for both signals.
dcope17 is offline
post #7 of 9 (permalink) Old 02-03-2009, 11:15 PM Thread Starter
Its a 2004
ok so 2 10ohm 10 watt resistors per side for a total of 4? Thank you for the help
post #8 of 9 (permalink) Old 02-04-2009, 12:06 PM
dcope17's Avatar
Yep... total of 4.
dcope17 is offline
post #9 of 9 (permalink) Old 02-04-2009, 09:43 PM Thread Starter
dcope17, Thank You! I got 4 10 Watt 10 Ohm resistors from radio shack today for just under $4. I have installed one on each side and tested. Im pretty happy with the fast blink rate thus far but I will try with 2 on each side.
Thanks again
