Motor locked up - 600RR.net
post #1 of 16 (permalink) Old 02-12-2009, 11:11 AM Thread Starter
dcraige's Avatar
Motor locked up
I went to start my 03 600rr and after about 2 seconds of starting I hear a clunk. I try to start it again and all I get is a click and dimming headlights. So I put it in gear and try to rock it back and forth but the tire just slides and the motor is locked up some how. Everything is stock except for a slip-on and I always check and change the oil since it was brand new. I am going to tear into it this weekend but was wondering if this had happened to anyone else. Thanks.
dcraige is offline
post #2 of 16 (permalink) Old 02-12-2009, 11:19 AM
Sounds to me like your battery needs a good charge. Put it on a battery tender/charger for a while then try starting the bike again.
The engine has a lot of compression and you won't be able to turn the rear wheel while it's in grear simply by pushing the bike. You'll need a fair bit of momentum before you can drop it into gear and have the engine turn over. Do some searches on bump starting a bike for futher details.
firestorm79 is offline
post #3 of 16 (permalink) Old 02-12-2009, 11:32 AM Thread Starter
dcraige's Avatar
I always keep my batt on a tender and it is new and fully charged. The question is not IF the motor is locked but what would be the most likley cause of it locking up?
dcraige is offline
post #4 of 16 (permalink) Old 02-12-2009, 12:03 PM
In that case it could be seized piston(s), broken or stretched timing chain, crankshaft bearings, or even the clutch plates could be stuck together.
If you're seriously worried about the engine being seized I'd recommend taking it into a shop and having them look at it. You could damage it further by messing around trying to get it to work.
post #5 of 16 (permalink) Old 02-12-2009, 12:18 PM
dcope17's Avatar
I agree with firestorm with one exception... you can mess with the motor... it is cheaper to get a used motor off of ebay then to repair the one you have. So if your motor is seriously junk... it won't hurt to mess it up more.
dcope17 is offline
post #6 of 16 (permalink) Old 02-12-2009, 12:19 PM
3L3C7R0's Avatar
Images: 13
I don't think its seized ether... Like he said, you can NOT just rock the bike and expect it to try and turn over. You have to get a running start. Before ANYTHING, I'd try a new battery. Maybe the tender went bad and over charged the battery thus rendering it a bad battery.
3L3C7R0 is offline
post #7 of 16 (permalink) Old 02-12-2009, 12:28 PM
LonelyRR's Avatar
Images: 241
Is the clutch pulled in when your rocking it in gear?
other question is it a battery tender or charger?
Some charger can damage the battery.
LonelyRR is offline
post #8 of 16 (permalink) Old 02-12-2009, 12:51 PM
I recommended taking it to a shop because if you don't know what to look for and/or fix you could cause more damage and incur more expenses than necessary. For example if the cam chain is the issue you could bend/break valves by trying to start the engine. Knowing the issue is the chain and replacing it would be a lot cheaper than doing a valve job as well.
post #9 of 16 (permalink) Old 02-12-2009, 01:11 PM Thread Starter
dcraige's Avatar
I know you can't turn the bike over just by rocking it but it has a different feel to it when I do rock it back and forth. I swaped the battery with a good one of another bike and no change. I have had bikes with dead batterys in my 20 years of riding and the battery is not the problem. I have done rebuilds and engine swaps before so if the engine need too much work I'll just replace it. I was just looking for anyone who HAD a 600rr lock up before and to see if their was any common problem.
dcraige is offline
post #10 of 16 (permalink) Old 02-12-2009, 01:20 PM
yellow_RR's Avatar
Images: 31
Sounds like a clutch issue to me. Watched my friend burning out his back tire and the exact same thing happend to him when we tried to leave. Was about $1200 to repair :(
- 2005 Red/Black 600RR
PC3 USB
Two Brothers M5 CF exhaust
K&N air filter
Dyno-tuned
Custom seats
Puig DB windscreen
Greg's Customs turn signals
CA Smoked Integrated Tail Light
Black PC'd rear pegs + Tripage LED
Pazzo Levers - short Red/Black
Red EKMVZ 520 chain
Driven sprockets (-1/+1)
Speedo-healer
Red rim tape
Frame bolt plugs
Mesh vent mod
Heated grips
Pirelli Corsa 3's
Electric Vehicle (EV) Infrastructure Implementation Experts- http://www.ecosparktech.com
yellow_RR is offline
post #11 of 16 (permalink) Old 02-12-2009, 01:26 PM Thread Starter
dcraige's Avatar
Can you expand upon this clutch issue? What clutch part failed? Thank you.
dcraige is offline
post #12 of 16 (permalink) Old 02-12-2009, 03:27 PM
dcope17's Avatar
Well put...I can agree with that too.
dcope17 is offline
post #13 of 16 (permalink) Old 02-12-2009, 08:52 PM
I'd check to see if the starter motor is jammed in there, 2nd I'd pull the clutch cover and see what shape it was in.
mike6001 is offline
post #14 of 16 (permalink) Old 02-14-2009, 10:08 AM Thread Starter
dcraige's Avatar
I'm going to get to work on it this morning and I'll post some updates later.
dcraige is offline
post #15 of 16 (permalink) Old 02-14-2009, 10:14 AM
Feedback Score: 7 reviews
if the bike is in gear and the clutch is not pulled in it wont roll or start
maybe i missed the part about it not moving in N or with the clutch pulled in but i am in a hurry this morning
RShackleford is offline
post #16 of 16 (permalink) Old 02-14-2009, 10:17 AM
powermoose1's Avatar
Images: 63
Feedback Score: 12 reviews
Interesting. Keep us posted. BTW, I love that avatar.
www.LMGTFY.com --> give it a try before you ask
Thanks for driving that hybrid...and saving all the gas for me!
powermoose1 is offline
