oil and gas leaking from drain tube... - 600RR.net
post #1 of 15 (permalink) Old 02-24-2009, 02:07 PM Thread Starter
Unhappy oil and gas leaking from drain tube...
Need help. I noticed a stain in my drive way after taking a break from riding. There is a fluid leaking from one of the two drain tubes. It has the smell of gas, but has the tint and texture of oil. the bike is a 2008 cbr600rr, w/5000 miles. Oil is changed every 2000 miles and i use 3 quarts of amsoil 10w-40. I don't know if it is relevant but I just installed a 2 bros. slip-on a week ago. Any help is greatly appreciated.
deja vu is offline
post #2 of 15 (permalink) Old 02-24-2009, 02:12 PM
jsteckelberg's Avatar
If the fluid is visually leaking (drop, drop, drop...) then we have a problem. Otherwise, it sounds like a little patch just sitting there after a while and that shouldn't be an issue. I've seen that under my bike, smelled the same, felt the same, I just figured "hey, they're drain tubes for a reason"...
jsteckelberg is offline
post #3 of 15 (permalink) Old 02-24-2009, 04:02 PM
JPRaceCraft's Avatar
If I fill my 07 slam full of gas on a hot engine and park it for a few minutes. The tanks will heat up and sweat gas out the vent tube . Only when parked slam full and hot. You may have ran into that situation as well .
The information provided by JPRacecraft on this website "600RR.net" is for reference only. JPRacecraft does not accept any responsibilities for any loss or damage whatsoever arising from any cause whatsoever in connection with this post . Users are responsible for making their own assessments of all information contained in or in connection with this post . Obtain independent legal counsel before acting upon any and all advice herein.
JPRaceCraft is offline
post #4 of 15 (permalink) Old 02-24-2009, 07:52 PM
That oily drip down near the kickstand? That's probably coming from the drive sprocket area. It's a common place for chain fling too drip down from. On my 06 it drips down the front side of the sprocket and then down the side of the oil pan and kickstand area to the floor. Are you sure it is actually fluid coming out the tube? Check again with a light and trace the drips. Wipe it and go ride a bit then check again.
"People take different roads seeking fulfillment and happiness. Just because they're not on your road doesn't mean they've gotten lost."
"The proper gear can make the last guy finish first!"
"I didn't lose my mind, I sold it on Ebay."
James06CBR is offline
post #5 of 15 (permalink) Old 02-24-2009, 09:28 PM Thread Starter
I layed down on the ground and looked up near, around, and in the tube. The fluid is definitly coming from in the tube. The tank is 3/4 full. However I wiped the tube dry, rode it and checked again. It is not leaking any more, or at the moment. I guess I'll take it to the stealership if I see it again. Thank you for the replies though, much appreciated! Quick question if anyone wants to give there .02 , should I look into a extended warrany before the factory runs out?
deja vu is offline
post #6 of 15 (permalink) Old 02-26-2009, 11:25 AM
Depends. If you can afford to throw down that cash on some extra piece of mind go for it. It's also a good thing to have when selling the bike. Do I think you will actually end up using it? NO.
post #7 of 15 (permalink) Old 02-26-2009, 03:05 PM
shiftn3rdon1's Avatar
Why do you only use 3 qts?
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #8 of 15 (permalink) Old 02-26-2009, 05:13 PM
my 06 is black and the tank get hot as hell when sitting in the sun mine will sometimes drip a few drops makes a spot about the size of a quarter
sdime95 is offline
post #9 of 15 (permalink) Old 02-26-2009, 05:17 PM
MXRider's Avatar
Feedback Score: 17 reviews
those are OVERFLOW tubes, what is happening to your bike is normal, stop worrying.
because thats how much oil the engine takes.
its actually 2.8L w/ a filter change, which is just under 3 quarts.
MXRider is offline
post #10 of 15 (permalink) Old 03-02-2009, 05:40 PM
Dr. GoFast's Avatar
one of those is a coolant overflow hose, the other is a fuel overflow hose. it is either coolant, fuel, or both- not oil.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #11 of 15 (permalink) Old 03-04-2009, 10:16 AM
Quagmire's Avatar
One hose is a coolant overflow tube, one is a crankcase ventilation tube (heat will expell tiny amounts of oil) don't worry about it, and the other is the fuel tank vent tube.
I had an issue once with these tubes that I was un-aware of. I was doing a trackday and had full race bodywork on the bike. Meaning that the underbelly was toatally enclosed. Well, the night befor the trackday, it rained like Pigs and rabbits. The underbelly had about three inches of water sitting there (did not have a drain hole/plug installe yet). When I started the bike, it ran fine for about 5 seconds then died. What I didn't know was, when the fuel pump primes and that little vent tube from the tank was submerged in the water was bad ju-ju. When the pump primed (creating a vacuum) it sucked up a bunch of water and ceremoniously introduced it into the gas tank....water in fuel.....very bad. Anyway, I was up 'til 2am trying to drain all the gas out of the tank and lines. But the spark plugs were soaked with water droplets and would not fire. I had to wait until the local bike shop opened to get new plugs to install. I missed the first hour of the track day trying to get the bike to run.
Lesson learned on my part....$67 for 4 plugs....what a day.
Quagmire is offline
post #12 of 15 (permalink) Old 09-11-2011, 05:03 PM
i am having the exact same issue. oil substance with gas odor coming out of one of the vent tubes. 2010 cbr600rr 5000mi. just occured today for the first time. idk what the deal is with it????!!!!
cbr6rr10 is offline
post #13 of 15 (permalink) Old 09-12-2011, 07:47 AM
Nico's Avatar
Could be gas mixing with chain lube leaking down...
My advice: Don't worry about it unless it continues to happen.
Nico is offline
post #14 of 15 (permalink) Old 09-12-2011, 08:22 AM
awesome bro, my bikes red but my tanks black, just like yours
spacecadet is offline
post #15 of 15 (permalink) Old 09-12-2011, 10:07 AM
em2b96p's Avatar
I think that's crankcase breather blowby fluid. Its supposed to go back into the airbox to be sucked back into the engine. Older Honda's (CB) had a stopper plug at the end of the drain tube. You would remove the plug and nasty brown oil and gas would come out.
Check to make sure the tube isnt gummed up.
em2b96p is offline
