the infamous engine tick - 600RR.net
post #1 of 13 (permalink) Old 03-06-2009, 04:11 PM Thread Starter
SteamyTaters's Avatar
so im prettyyyy sure its my injectors.
i did do some research, but i didnt really find an answer to my question.
i was wondering if its safe to put a cleaning solution in with my fuel, every so often i use this prolong fuel additive in my car, mixes right in with the gas and helps keep the injectors and such clean.
think its safe to use a small amount of it in my bike?
what other solutions are there?
thanks.
SteamyTaters is offline
post #2 of 13 (permalink) Old 03-06-2009, 05:33 PM
SPACEBOY's Avatar
I've used small amounts in mine. Cant say I've ever had any problems from it.
Brendan
'03 Red/ Black 600RR (Track)
'06 Silver/Grey GSXR 1000 (Street)
http://www.southwestsportbikes.net
SPACEBOY is offline
post #3 of 13 (permalink) Old 03-06-2009, 05:55 PM
Feedback Score: 7 reviews
dont use a lot.
most car solutions are forumlated for more gas than a bike tank is.
maybe an ounce of seafoam
RShackleford is offline
post #4 of 13 (permalink) Old 03-06-2009, 06:00 PM
Draconis33's Avatar
Images: 3
I have done it before in previous machines. Usually the bottle will say that it is for 12+ gallons of fuel or so. I split the bottle into 4 smaller bottles and used it every couple of fill-up (or so). I have never had a problem with it. Of course, I have never used it on a fuel injected bike. All my previous bikes were carb.
Draconis33 is offline
post #5 of 13 (permalink) Old 03-06-2009, 07:40 PM
ccc1997 is offline
post #6 of 13 (permalink) Old 03-07-2009, 12:10 AM
bad06rr's Avatar
You own a Honda. Therefore, the camchain tensior needs to be replaced. Buy this. Part number HT600RR. Install is very easy. Remove right side mid and you'll need a 5mm (I think it's 5mm, don't remember) allen. Any questions shoot me a pm.
http://cbrzone.com/sprockets.html
Originally Posted by sincalirider View Post
Myspace
facebook: pm I'll add you
bad06rr is offline
post #7 of 13 (permalink) Old 03-07-2009, 12:22 AM
murphdog1411's Avatar
Images: 94
Originally Posted by RShackleford View Post
dont use a lot.
i think the standard seafoam container is for 10 gal. so it would be fine to use half of it. i have in the past and love the stuff!!
murphdog1411 is offline
post #8 of 13 (permalink) Old 03-07-2009, 02:43 AM
R3DS2K's Avatar
Feedback Score: 6 reviews
injectors are suppose to tick. some louder than others but i do believe this is your camchain tensior like bad06rr said which i also heard is normal?
R3DS2K is offline
post #9 of 13 (permalink) Old 03-07-2009, 02:54 AM
cal_look_zero's Avatar
Hmmm, I'm gonna look into that tensionermabob. I did my valves at 20k (no shims baby, <3 my honda) and I assumed that was it up to that point, so I left well enough alone. I've ridden a few other 600rrs that all sounded like mine (with the tick) and assumed it was nature of the beast? Is it harmful or just annoying? Thoughts?
cal_look_zero is offline
post #10 of 13 (permalink) Old 03-07-2009, 02:55 AM
R3DS2K's Avatar
someone that knows better will chime in but i hear mine everyone once in a while. i hate it.
R3DS2K is offline
post #11 of 13 (permalink) Old 03-07-2009, 09:37 AM
Quagmire's Avatar
Is the "Tick" always there at all RPM's? Or is it just around 5000-5500 RPM? If it is the second, it is your CCT. Even the new (OEM) CCT's are subject to the rattling (sounds like BB's in a soda can). I did the modification on my new CCT and it is as quiet as Honda's factory race team this year....
Quagmire is offline
post #12 of 13 (permalink) Old 03-07-2009, 11:07 AM
bad06rr's Avatar
If you have that many miles and you have yet to replace the cam chain tensioner I would do it regardless. It's only $50, take less than 10 minutes to install even for someone who has never worked on bikes before, and will make the bike run better. Sounds like a no brainer. I had to replace mine at 8,000 and many people have had to replace theirs sooner. I'll do a How-To for you tonight if you want and walk you through it.
Myspace
bad06rr is offline
post #13 of 13 (permalink) Old 03-07-2009, 11:48 AM
bad06rr's Avatar
Here you go, I got bored at work and made a how-to out of google pics.
https://www.600rr.net/vb/showthread.p...64#post2123164
Myspace
bad06rr is offline
