Headlight problems - 600RR.net
post #1 of 34 (permalink) Old 03-12-2009, 11:48 AM Thread Starter
Gat0rBait's Avatar
Feedback Score: 7 reviews
Headlight problems
Ok so yesterday as im leaving for work I start the bike up to let it warm up a little and notice the headlight doesnt come on... i finish putting my gear on and by the time I am done the headlight is on, so im thinking no big deal.
However this morning i start the bike and same thing no headlight except this time i waited and waited and nothing, i drove to work anyways the whole time trying to see if it comes on or play with the "brights" switch. When i turn the brights switch on it does not indicate on my cluster, nor does it turn on. Everything else works fine, brake light, turn signals everything.
As soon as i get to work it turns on and now when i turn the brights on the other light comes on and it is indicated on my cluster...
So is there maybe somthing simple i could check a lose connection or? I just thought it was wierd because even though i turn my brights on the light on my cluster wouldnt come on.
Gat0rBait is offline
post #2 of 34 (permalink) Old 03-12-2009, 11:53 AM
KylerR's Avatar
dunno, check your fuses, and where the bulbs plug into the sub harness, maybe even a short in your switch?
Bring a spare clutch lever and drive it through his heart. It's the only way to kill a bike thief."-ZachRR
KylerR is offline
post #3 of 34 (permalink) Old 03-12-2009, 11:54 AM
SchaadeS's Avatar
Thought maybe its a fuse... but now it sounds like a loose connection. Check all your hook ups, and make sure they are all securely done up. Maybe your bulb is burnt out?!? I really dont have much of a clue other then that.
-Shelby
https://www.600rr.net/vb/showthread.php?t=124351
D3 Grips, O'Grady Paint, Powder coated everything, Custom LED switching, Tripage Third Eye, Custom LED Gauge Cluster, 6000K HID's, Integrated Mirrors with Signals, Integrated Signal/Brake light, Driven Sprocket Kit -1/+2, EK Chain 520 Pitch, PC3, Quickshift kit, Multi mapping touch screen, Block Off Plates, BCM Air Filter, DIY Short stack Air Mod, Speedohealer, Galfer Stainless Steel Brake lines, 450R mod, Yoshi pipe, Arrow Headers.
SchaadeS is offline
post #4 of 34 (permalink) Old 03-12-2009, 12:01 PM Thread Starter
Gat0rBait's Avatar
well the bulbs arnt burnt out because they do both come on but like i said it was delayed, yesterday only a minute but this morning prolly 30...
if it was a fuse then wouldnt it not come on at all? unless its a loose fuse?
post #5 of 34 (permalink) Old 03-12-2009, 12:11 PM
KylerR's Avatar
yea if the fuse was burnt you would have no light
if the bulb was burnt there would be no light
it's got to be a short in your wiring or a loose connection of either the fuse or the bulbs
KylerR is offline
post #6 of 34 (permalink) Old 03-12-2009, 12:13 PM
KylerR's Avatar
the fact that it doesn't show in your cluster when u turn the brights on makes me think a short in your actual switch possibly....
but then why would the low beam not come on also?
KylerR is offline
post #7 of 34 (permalink) Old 03-12-2009, 12:17 PM
BLUETORI's Avatar
Mine use to do this as well but has stopped for the time being. But it seemed to fix it self was wierd and seemed hard to deal with seeing as I like riding with the brights on as well.
PM me if you have a red clip for an Arai side pod.
BLUETORI is offline
post #8 of 34 (permalink) Old 03-12-2009, 12:20 PM
shiftn3rdon1's Avatar
100% know its in your kill switch. Tear it apart, and remove the metal cover thats on the bottom side of the switch I believe, and there is a white/blck wire (I THINK) that has a solder tab on there. It just came unsoldered. Check it out, thats most likely the culprit. Happened to alot of us.
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #9 of 34 (permalink) Old 03-12-2009, 01:47 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Like suggested check the kill switch also check out the
prongs for the black base that holds the bulb itself its
common to have a short in one of the prongs which causes
the problem you got the base is replacable for 5.95
Moeman is offline
post #10 of 34 (permalink) Old 03-12-2009, 04:06 PM
dcope17's Avatar
I'd go 99%. Could be a burnt bulb but most likely... kill switch.
dcope17 is offline
post #11 of 34 (permalink) Old 03-12-2009, 04:10 PM
slimdesel17's Avatar
just curious, was the bike ever down?
1983 Kawi Kz750 LTD (sold)
1976 Kaxi kz900 z1 (current)
1991 Honda CBR 600 F2 (sold)
1994 Honda CBR 600 F2 (sold)
1998 Suzuki Bandit streetfighter (sold)
1998 Honda CBR 600 F3 (sold)
1995 Honda CBR 900RR (wrecked/fixed/sold)
2005 Honda CBR 600RR (WRECKED)
1980 Yamamha mx 100 (BEAST!)
2003 Yamaha R1 special edition (current)
Gloves Dont WORK MIRACLES!!!!
slimdesel17 is offline
post #12 of 34 (permalink) Old 03-12-2009, 05:27 PM Thread Starter
Gat0rBait's Avatar
Exactly my thoughts... if this is a switch issue like people are saying that has nothing to do with my low beam it is on by default...
post #13 of 34 (permalink) Old 03-12-2009, 05:29 PM Thread Starter
Gat0rBait's Avatar
not a burnt bulb people
Originally Posted by SkinnyJdcope17
I'd go 99%. Could be a burnt bulb but most likely... kill switch. ?
post #14 of 34 (permalink) Old 03-12-2009, 06:25 PM Thread Starter
Gat0rBait's Avatar
rode it home from work and didnt have a problem, i did wash it this past weekend so perhaps water shorted somthing out?
i checked the prongs/connectors, those wires everything near the headlight assembly looks ok :(
post #15 of 34 (permalink) Old 03-12-2009, 09:59 PM
dcope17's Avatar
It's the start button/ kill switch. When you push the start button, it turns off the low beam headlight while it is starting the bike. When you let off the starter button... the light comes back on. Also when you hit the kill switch... it turns off the low beam too.
We're not talking about the high beam switch.
dcope17 is offline
post #16 of 34 (permalink) Old 03-12-2009, 11:01 PM Thread Starter
Gat0rBait's Avatar
ok that makes sense what your saying but why would that effect the high beam? ie i turn the high beam on it doesnt come on and it is not displayed on my cluster
post #17 of 34 (permalink) Old 03-13-2009, 12:55 AM
dcope17's Avatar
Sampsonite, I was way off. Your high beam has a relay. Check it out. You can switch it with the fan relay and if that fixes it... then buy a new relay. If it doesn't fix it... well, we'll cross that bridge when we get there.
dcope17 is offline
post #18 of 34 (permalink) Old 03-13-2009, 12:58 AM
dcope17's Avatar
Oh, the indicator in the cluster and the high beam light are wired parallel. Meaning even if the bulb was shot... the indicator would still turn on. So I think you wiring problem is the relay or somewhere before the relay.
dcope17 is offline
post #19 of 34 (permalink) Old 03-13-2009, 10:48 AM Thread Starter
Gat0rBait's Avatar
Ok well rode again to work and not one problem, so for the time being i will keep this thread on the backburner but i do appreciate the advice so far though guys.
post #20 of 34 (permalink) Old 03-13-2009, 08:09 PM
Its prolly a lose wire in the killswitch!
post #21 of 34 (permalink) Old 03-13-2009, 08:16 PM
NraGed's Avatar
Feedback Score: 5 reviews
What he said.^^^^ Seen this before, and yes...it could be water related, but it is the kill switch. If it's not acting up since you "dried" it out, then resume riding, but you know what you need to do to solve it if it happens again.
You can try wetting the kill switch area or smacking it while bike is running to get a feel for the problem if you feel energetic. It might give you an idea how bad it is (water entry OR loose connection).
2005 600RR - SOLD
2007 600RR - SOLD
NraGed is offline
post #22 of 34 (permalink) Old 03-14-2009, 11:17 AM Thread Starter
Gat0rBait's Avatar
Ok so if it is a faulty kill switch then why isnt it randomly killing the bike or anything?
post #23 of 34 (permalink) Old 03-14-2009, 02:04 PM
Feedback Score: 6 reviews
Is there a write up on this with pics? I think I might be having the same problem on my 03
mbh0114 is offline
post #24 of 34 (permalink) Old 03-16-2009, 12:31 PM
The killswitch house holds a few wire connections, one of them being the headlights. They are just soldered onto a little tab in the housing, which can easily become dissconnected. The wire that actually controls the killswitch is seperate.
post #25 of 34 (permalink) Old 03-16-2009, 06:45 PM
slab42's Avatar
Images: 13
I was thinkin it was the starter switch too, but you guys beat me to it. Does your starter button spring all the way out when you release it? +1 on taking it apart to make sure it is good. It is a double pole, single throw switch that basically allows current to pass to the headlight at rest, and when you press it in it breaks that circuit and completes the starter circuit. My money is on a problem with the starter switch. Here is a pic of the switch schematic to help you better understand how it works. I put red dots on the two contacts that the switch connects when at rest (headlight circuit) and blue dots on the two contacts that the switch connects when you press it in (starter circuit)
06 Silver 600RR
My mod thread
slab42 is offline
post #26 of 34 (permalink) Old 03-17-2009, 10:53 AM Thread Starter
Gat0rBait's Avatar
Thanks! My start switch does seem to operate fine, comes out all the way and quickly etc. When I have some time i do plan on taking it apart and checking the connections.
post #27 of 34 (permalink) Old 03-24-2009, 08:54 PM
I just had this same problem and upon reading this article, it turns out it was the kill switch,
cbrbamby is offline
post #28 of 34 (permalink) Old 03-26-2009, 10:53 AM
slab42's Avatar
Images: 13
what was your remedy? new switch, or were you able to fix it?
06 Silver 600RR
My mod thread
slab42 is offline
post #29 of 34 (permalink) Old 03-27-2009, 10:27 PM
currently, nothing, I just hit the kill on and off and they work now.
cbrbamby is offline
post #30 of 34 (permalink) Old 03-30-2009, 01:14 PM
You should prolly tear it apart and fix it. It is most likely just barley touching the contact. You could be riding at night and hit a bump and walla, no headlights. It is an easy fix.
