starting problems - 600RR.net
post #1 of 7 (permalink) Old 07-07-2009, 05:58 PM Thread Starter
Unhappy starting problems
I have a 2004 cbr600rr with 5000 miles on it. I am having a hard time starting it after I go for a ride.
This morning it will start just fine and I will go maybe 1 mile to the gas station fill up then start it and nothing happens. The fuel pump turns on but no start not even try to turn over. I have replaced the starter and battery so I know that they are both fine and I still have this problem.
Any help would be great.
smatana1 is offline
post #2 of 7 (permalink) Old 07-07-2009, 08:58 PM
check the plugs
02blueR6 is offline
post #3 of 7 (permalink) Old 07-09-2009, 11:53 AM Thread Starter
Originally Posted by 02blueR6 View Post
check the plugs
plugs are fine
battery fine
starter fine
wires are all good
smatana1 is offline
post #4 of 7 (permalink) Old 07-09-2009, 12:27 PM
RawRR's Avatar
Feedback Score: 5 reviews
reg/rec?
get a gen 2
RawRR is offline
post #5 of 7 (permalink) Old 07-10-2009, 02:54 AM
oneredrider's Avatar
looks like it's the same problem i'm having. i've narrowed it down to whether it's the stator or the rectifier/regulator. will do some testing this weekend. let me know if you're able to solve the problem first. good luck.
bO! !Od
bike mods:
hotbodies undertail exhaust
crg shorty levers
gel grips handles
LP DB windscreen
gilles rearsets
vortex swingarm spools
powder coated swingarm
painted engine case
shogun frame sliders
k&n air and oil filters
custom rear seat cowl
stomp grip tank pads
DDM Tuning HID's 35w 8000k
and most of all: flat black body paint.
oneredrider is offline
post #6 of 7 (permalink) Old 07-11-2009, 06:49 AM Thread Starter
ok I tested the R/R and it is fine. Weather looks like rain here on sunday and I will be going through the whole bike. It is not a charging problem because I checked the battery when it happened and it is fine.
any other sug...?
smatana1 is offline
post #7 of 7 (permalink) Old 07-12-2009, 10:48 PM
dcope17's Avatar
If checking the battery when it happend means...that you were checking the battery voltage while holding the starter button. When you push the start button, you should have at least 10V If so, the check the voltage after the relay, If that's good, then you need to check the voltage at the terminals of the starter.
If all that's good, then the rest is mechanical.
dcope17 is offline
