Neutral problem - 600RR.net
post #1 of 6 (permalink) Old 07-13-2009, 09:09 PM Thread Starter
Neutral problem
I have a 2007, and the neutral light doesnt work like it should. When I first turn the key, the light comes on, but then when the bike is on and in neutral it doesnt work at all. Can anyone help. I know the wire is hooked up correctly because I removed the switch and the indicator and they all look fine.
Mecaman is offline
post #2 of 6 (permalink) Old 07-14-2009, 11:31 AM
maybe the nutral switch is bad
02blueR6 is offline
post #3 of 6 (permalink) Old 07-14-2009, 02:28 PM
dcope17's Avatar
Bad switch, bad connection, broken wire. All these can cause your problem.
Take the wire off the switch and touch it to the crankcase. Does it light up, then the wire is good, then it's just the switch or connection. Just eliminate one possibility at a time.
dcope17 is offline
post #4 of 6 (permalink) Old 07-16-2009, 07:53 AM Thread Starter
Today I tried removing the wire, and grounding it, and nothing happened. When I removed the wire from the neutral switch the idle went a little low. I also replaced the switch with a new one, and still nothing. I think the wire is good because the bike wouldnt start unless the wire was grounded. but still no light. Thank you for your suggestions. Anything else I can look at?
Mecaman is offline
post #5 of 6 (permalink) Old 07-16-2009, 11:38 AM
dcope17's Avatar
let me look at the wiring diagram after work and I'll get back to you.
dcope17 is offline
post #6 of 6 (permalink) Old 07-16-2009, 01:52 PM
my 04 was doing the same thing.. i would put it in neutral but the light wouldn't appear and i couldn't leave the bike running in neutral with the kickstand down cause it wasn't recognizing... all i did was take off the connect which was located directly above the gear lever and make sure all wires were touching... it works fine now
SpecialK is offline
