03 HEAT Problem again! Please help - 600RR.net
post #1 of 4 (permalink) Old 07-14-2009, 02:51 AM Thread Starter
OK my 03 600 RR is doing the heat thing. What should i do? Please help. I can ride my bike just fine until it gets warm (like 200). Once it reaches that point or even sometimes sooner, my bike will just shut off. I can ride just fine on the freeway, but the second i pull in the clutch, the darn thing shuts right down and acts like battery is dead. I can let it cool down and sometimes it will fire right up and sometimes it wont. Pop staring it seems to work just fine. I have also noticed that if I cost in to an intersection/stop and dont give it gas at all, sometimes it will stay running? Really weird. But please someone help! I have changed the starter, the battery. Even bought a $160 battery for it, still no luck. What to do. Can i make it so that my fan kicks on at like 180 or so, would that be possible or even hard on the engine?
wayned87 is offline
post #2 of 4 (permalink) Old 07-14-2009, 03:25 AM
Tommy1979's Avatar
Damn bro, this doesn't sound good at all. I don't have a clue what would cause this but I'd recommend that you post this in the correct forum. This forum is just for you to give your intro and tell us a little about yourself. If you post this question in the "troubleshooting" forum, you'd have a better chance of someone helping you out.
Welcome to the site and good luck with your bike bro
Tommy1979 is offline
post #3 of 4 (permalink) Old 07-14-2009, 09:49 AM
what kind of oil are you using? My bike likes to get hot and overheat when I'm stuck in bad summer traffic (I'm talking 235-245*F... not 200*F) and I noticed if my oil was a little low, using the clutch would kill the motor.
Your clutch is lubed by the same oil as your engine. You get it too hot, it'll burn off the oil a little bit. So make sure your oil levels are good: park your bike on a level surface on the kick stand and look at the oil level 'window.' It needs to be half oil half air. If you can't see any oil, fill it up or give yourself an oil change and put in the correct amount.
Unless you have a bad clutch....
flintoid is offline
post #4 of 4 (permalink) Old 07-14-2009, 09:52 AM
just thought of something: 220*F is when your fan kicks on....
is it kicking on and draining your battery immediately? You might have a short with the fan relay or something. I bet that's your problem: once it kicks on it kills your electrical system.
flintoid is offline
