oil sheen in engine coolant? - 600RR.net
post #1 of 5 (permalink) Old 07-15-2009, 09:29 PM Thread Starter
michaelwood's Avatar
what's up with that? I took the cooland out with an extractor pump. GOt almost all of it out. Earlier, I had ridden the bike home with a bent cooling pipe. I stopped every 10 minutes and topped up with water, misted the radiator to cool it, misted the entine after a few minutes with spray, topped her up again, wated another 5 minutes, etc.
Stopped 2 times on my way home, it was not very far. I had ridden miles without doing any damage on my old R6. Miles and miles at hithway speed with an empty radiator (don't ask)
anyways. I guess I should flush the system...right? If any more shows up, or if it smokes, I guess it's done for. WHat do you say? What about using a clear hose?
Oh, and another possibility......THe extractor pump was previously used for oil, so, that might be it, just examining the possibiulities. It owuld be nice to get a high compression head gasket and this might be just the excuse!
michaelwood is offline
post #2 of 5 (permalink) Old 07-15-2009, 09:56 PM
ibbob50's Avatar
Originally Posted by michaelwood View Post
...I took the cooland out with an extractor pump...
I can darn near guarantee you, your oily sheen is from using an oily pump. If you had a blown head gasket, you'd notice more than just a "sheen"!
ibbob50 is offline
post #3 of 5 (permalink) Old 07-15-2009, 10:07 PM
murphdog1411's Avatar
Images: 94
and it would run for poop.
murphdog1411 is offline
post #4 of 5 (permalink) Old 07-15-2009, 10:17 PM
chipmunkofdoom2's Avatar
Head gasket. Sorry bro.
Squid test:
So far, 13109 people (including you) have responded to this Squid Test Survey and have been tabulated.
Of those responses, the average grade is 53. Your grade was 82 (from 0 to 100)
A higher grade indicates a stronger sense of common decency, and a lower grade is an indication of conspicuous squidliness and general disregard for civilized society. Your score indicates that you are a fairly responsible motorcyclist but a bit of a wise-ass.
Hahaha.
chipmunkofdoom2 is offline
post #5 of 5 (permalink) Old 07-15-2009, 11:43 PM
dcope17's Avatar
Well, first off, you didn't get almost all of it out if you used an extractor pump. There is a drain bolt by the water pump and even that doesn't get it all out.
Next, a bent pipe??? Was it leaking too, then its not a bent pipe, it is broken and coolant is spilling out.
I think, if you want to keep from spending a lot of money, take your bike to the dealership for repairs. And don't ride a bike that you have to stop and spray water on the radiator and engine to keep it cool.
dcope17 is offline
