No rear brake - 600RR.net
post #1 of 18 (permalink) Old 07-22-2009, 10:16 AM Thread Starter
StealthscrapE's Avatar
No rear brake
I did a search for bleeding brake lines and such and haven't found anything useful. I swapped out my rear brake line after a retarded mistake I made that ended up in my old line being torn in half.
So I swapped out the line and everything hooked up well, but I still have no rear brake. It is a little stiffer than it was when the broken line was on there, but it still drops all the way down. I don't know if I'm missing something or just bleeding it wrong, but I need some help. Do you need a tube to bleed it, or can you bleed it without the tube? I worry riding around with no rear brake. You always need something when you don't have it. Any help is much appreciated.
2008 CBR 600RR Graffiti
TBR , Tripage, Gilles, ASV, Woodcraft, Rizoma, Watsen
Install Videos:
IT Install - From Stock
IT Install - From Aftermarket
Exhaust install 07-08 (possibly 09-10?)
LED Peg Install
HID Delay Install
StealthscrapE is offline
post #2 of 18 (permalink) Old 07-22-2009, 10:21 AM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
There should be a pressue spring on the back side of the brake pedal
make sure that is hooked up
Moeman is offline
post #3 of 18 (permalink) Old 07-22-2009, 10:23 AM
Back in the Day
Moeman's Avatar
Images: 665
This might help see what i am talking about PART # 5 is the sring stop switch
Moeman is offline
post #4 of 18 (permalink) Old 07-22-2009, 10:25 AM
Back in the Day
Moeman's Avatar
Images: 665
If that is hooked up and all check the dial itself part # 4 switch RR stop that might not be dialed up right post back the results of both tests
Moeman is offline
post #5 of 18 (permalink) Old 07-22-2009, 10:42 AM
Debt Management Counselor
Feedback Score: 46 reviews
if all of your connections are tight make sure that you are bleeding correctly. open the bleed valve on the caliper and press down on the lever. close the bleed valve THEN let the lever come back to the rest position. repeat. if you are opening the bleeder valve and pumping away at the lever all you are doing is introducing more and more air into the system.
make sure you are keeping the reservoir full as well. if it runs dry then air will get into the system as well.
adding a rear line will make a big difference on the back brake. 99% of the time people have less brake on the back is because of user error when bleeding the brakes.
http://www.superbikesupply.com
[email protected]
828-287-2101-sales
FEED YOUR EGO!!
http://www.facebook.com/superbikesupply
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
lexusrx is offline
post #6 of 18 (permalink) Old 07-22-2009, 11:27 AM Thread Starter
The spring is all hooked up and returns to the right position and everything, just no actual brake. I think I might be bleeding it incorrectly. How many times to you do cycle through like you are saying?
(open bleed valve, push rear brake lever down, close bleed valve, release brake lever, repeat)
Install Videos:
LED Peg Install
HID Delay Install
post #7 of 18 (permalink) Old 07-22-2009, 11:50 AM
krisboro's Avatar
I use a cheap one man brake bleeder that I got for about 6 bucks in autozone. It inserts into the hole in the bleed valve and you put a small amount of fluid in the provided bottle to prevent air going back up the hose. Works great for me.
Bleeding the brakes can take a little while to get everything cycling properly and all the air out.
My fronts took forever when I did a caliper swap. Be patient. I also found that just barely cracking the bleed valve open worked better for me.
krisboro is offline
post #8 of 18 (permalink) Old 07-22-2009, 11:59 AM
AlpineJim's Avatar
get a tube(about 3' in length)and a old bottle(fill the bottle with a little bit of water) Bleed away(there should be some good write ups I remember posting a few years ago) its going to take a while since your whole line is full of air.(If you replace lines again just fill them with brake fluid then attach them to the caliper.) Also make sure you have them torque to the right value.
Matthew
03' 600rr - Track
AlpineJim is offline
post #9 of 18 (permalink) Old 07-22-2009, 12:08 PM
it depends. you want to make sure all the air is out. if you have the system closed up (reservoir cap on,etc.) then once you close the bleed valve you should start getting brake. keep going until your brake is where you want it to be.
if you want, you can give me a call. ill be more than happy to go over a few things over the phone. its sometime better to convey what you mean that way versus writing it out.
brad
[email protected]
828-287-2101-sales
FEED YOUR EGO!!
08 cbr 1000rr
07 cbr 600rr
ΜΟΛΩΝ ΛΑΒΕ
lexusrx is offline
post #10 of 18 (permalink) Old 07-22-2009, 12:34 PM
Just a question about this topic, but I have Woodcraft rearsets and they have no place for the pressure spring in the MC.
Bike:
2008 CBR600RR "Graffiti"
Installed:
Full R&G setup
GCraft brake res
Tripage FE
Tripage LED passenger pegs
Woodcraft rearsets
20grit racing custom LED tail section
ASV shorties
Smoked windscreen
Wanted:
Galfer brake lines
Driven 520 conversion -1/+2
Akra full or SO
Bazzaz ZFi
Carrozerria GP brake mod
Wave rotors
Brembo monoblocs
Ohlins shock
hondaboy945 is offline
post #11 of 18 (permalink) Old 07-22-2009, 02:59 PM Thread Starter
Thanks for the help guys. I guess I just assumed it was good since the brake fluid was coming out the bleed valve, but I guess there is prob still a lot of air in there.
brad
If I take the reservoir cap off, will it be easier to bleed? (ie; make it flow through the system better) or is it better to leave it on?
What is the purpose of the water in the bottle? just so it won't eat through?
Install Videos:
LED Peg Install
HID Delay Install
post #12 of 18 (permalink) Old 07-22-2009, 03:23 PM
krisboro's Avatar
Water in the bottle is to prevent air from being sucked back up thru the tube and into your caliper. Also makes it easier to see the air bubbles in you fluid. When you see no more bubbles, you're good to go.
I usually use brake fluid instead of water(in the bottle)
krisboro is offline
post #13 of 18 (permalink) Old 07-22-2009, 03:49 PM
ProWakeskater's Avatar
umm, did no one else catch his mess-up?
I believe its
close valve, press brake lever (keep it pressed), slowly open the valve, press the fluid out, keep pressure on the brake, and dont let it go completely down, then Close valve.
ProWakeskater is offline
post #14 of 18 (permalink) Old 07-22-2009, 05:11 PM Thread Starter
I'm basing it off what lexus said here. Let me know if it is incorrect. makes sense this way. Your way makes sense too, but sounds more difficult.
Install Videos:
LED Peg Install
HID Delay Install
post #15 of 18 (permalink) Old 07-22-2009, 05:18 PM
R3DS2K's Avatar
Feedback Score: 6 reviews
I believe its
have cap open and read to add more fluid as need
R3DS2K is offline
post #16 of 18 (permalink) Old 07-22-2009, 06:19 PM
AlpineJim's Avatar
You need to buy a pressure switch banjo bolt...
Matthew
03' 600rr - Track
post #17 of 18 (permalink) Old 07-22-2009, 06:32 PM
Lifetime Premium
baked's Avatar
Images: 7
DO NOT BY ANY MEANS PUT WATER NEAR AN OPEN HYDRAULIC SYSTEM!!!!! Brake fluid absorbs moisture
fill with DOT4 fluid and just keep bleeding, try open/close method or the pump up and open method make sure you have the bleeder screw closed when you let off the pedal.
baked is offline
post #18 of 18 (permalink) Old 07-25-2009, 09:39 PM Thread Starter
bumping this up because I'm still having trouble trying to bleed without a tube on the bleed valve. Two different things have been said about the pattern to do it (open valve, pump, close valve, etc.) Thanks for any help.
Install Videos:
LED Peg Install
HID Delay Install
