Engine noise from a 2006 CBR600RR.[video] - 600RR.net
post #1 of 25 (permalink) Old 07-26-2009, 10:48 PM Thread Starter
Silver72's Avatar
My CBR is currently making a noise it didn't used to, I haven't dug too far into it as of yet just stripped the plastics. Figured I would video it and see if anyone could identify the noise. Seems to be coming more from the middle of the engine not lower in the engine where the valves would be. Help plz.
http://www.youtube.com/watch?v=TlkeZVFvp0I
Silver72 is offline
post #2 of 25 (permalink) Old 07-26-2009, 10:49 PM
murphdog1411's Avatar
Images: 94
what rpm is that @ where it was making it. other than that slight rattling, it sounded like an exhaust leak. if your refering to the rattle, if its b/w 5-6k, its a possible CCT
murphdog1411 is offline
post #3 of 25 (permalink) Old 07-26-2009, 10:50 PM Thread Starter
Silver72's Avatar
Added link. Yeah the [ youtube] doesn't seem to be working.
Silver72 is offline
post #4 of 25 (permalink) Old 07-26-2009, 10:51 PM
PoweredMotives's Avatar
Cam Chain Tensioner? My '03 makes the same noise.
PoweredMotives is offline
post #5 of 25 (permalink) Old 07-26-2009, 10:54 PM Thread Starter
Silver72's Avatar
I had looked around some and saw a few other threads on it but couldn't really pin it down. The 06 has an automatic CCT I believe, will it still sound like all the time and should I worry about it and replace with manual CCT?
The sound that worries me is more at idle. On the exhaust part where would I start trying to pin down where that would be at if it was leaking, as it has gotten a bit louder it seems coming from the engines when @ high RPM's.
Also sweet tits you guys are fast. THANK YOU.
Silver72 is offline
post #6 of 25 (permalink) Old 07-26-2009, 10:58 PM
Images: 94
How many miles on it? Also if it is exhaust, start the bike and grap a freind. have them cover the exhaust to restrict it. Not enough to stall the bike, but to dampen the sounds and force more exhaust out of anywhere it may be leaking. Do it with the bike cold so you can get your hand in and around the exhaust to feel and hear anything.
post #7 of 25 (permalink) Old 07-26-2009, 10:59 PM
Images: 94
also to post Utube you must use [ youtube ] TlkeZVFvp0I [ / youtube ]
no spaces between any of that.
post #8 of 25 (permalink) Old 07-26-2009, 11:00 PM
Yea I do believe it is automatic and so is mine however if it works how I think it does (like a serpentine belt tensioner on a car) the spring will wear out causing it to be loose and make noise.
Not 100% sure about this though. I've never taken mine apart.
post #9 of 25 (permalink) Old 07-26-2009, 11:01 PM Thread Starter
Silver72's Avatar
Stellar idea! Will do that tomorrow for the exhaust thing.
For mileage it's at 19,900. Checked the valves at roughly 16,300 and all were within spec. 6 of them were getting pretty close to being out of spec though.
edit: Ahh thanks, I had the [ youtube] but put in the full link.
Silver72 is offline
post #10 of 25 (permalink) Old 07-26-2009, 11:05 PM
Images: 94
your on the right track on how the CCT fails. It does wear out thus allowing it to have excess slack in the timing chain. i have 29k on her now with the origional CCT on. I will be changing it to the APE manual CCT very soon.
post #11 of 25 (permalink) Old 07-27-2009, 02:24 AM
dreamzboy's Avatar
If you can post up a how-to, it would help me greatly. Mine is at 31K and still running.
dreamzboy is offline
post #12 of 25 (permalink) Old 07-27-2009, 02:34 AM
I couldn't hear the noise in the video but if its coming from the right side by the frame then i would say its your cam chain.
Rossman2205 is offline
post #13 of 25 (permalink) Old 07-27-2009, 09:33 AM Thread Starter
Silver72's Avatar
How to on APE CCT replacement with pictures...
https://www.600rr.net/vb/showthread.p...&highlight=CCT
Also so on the CCT thing, for those who haven't done the APE replacement, does yours sound about the same? Just wondering how much noise I should worry about. Also don't want to grenade the engine or anything.
/learning how to work on motorcycles still.
Silver72 is offline
post #14 of 25 (permalink) Old 07-28-2009, 10:40 AM Thread Starter
Silver72's Avatar
Prognosis, slight cam chain rattle. Probably normal with the amount of miles I have on it as well as I just switched from a heavier oil to a thinner oil. Noise tends to go away at higher RPM's as well.
Going to slap the plastics back on her and probably do the APE thing when I do the next service. Checked for exhaust leaks and seem to be all good there as well.
Silver72 is offline
post #15 of 25 (permalink) Old 07-28-2009, 11:42 AM
kevinsheadphones's Avatar
what oil did you have in it before? and how long., what weight did you go to?
-------- Want to Buy / Parts list---------
right rear set
rear sprocket +3 525 chain and stock gearing 14 front spkt
also
02 Gixer 600 Parts , its a suzuki .. just tell me what u got
___________________________
Thanks to dotnetrs
dcope17 - infinate719 -
kevinsheadphones is offline
post #16 of 25 (permalink) Old 07-28-2009, 11:56 AM Thread Starter
Silver72's Avatar
I tried the rotella stuff which was 20-50 and went back to repsol at 10w-40
Silver72 is offline
post #17 of 25 (permalink) Old 07-28-2009, 12:06 PM
how long did you run 20w
right rear set
also
Thanks to dotnetrs
post #18 of 25 (permalink) Old 07-28-2009, 02:28 PM Thread Starter
Silver72's Avatar
roughly 3500 to 4k it was the white bottle too not blue bottle which has friction restrictors I think? Something like that. Didn't know that till I was changing the oil though.
Silver72 is offline
post #19 of 25 (permalink) Old 07-28-2009, 03:59 PM
what made you go with 20w?
right rear set
also
Thanks to dotnetrs
post #20 of 25 (permalink) Old 07-28-2009, 05:59 PM Thread Starter
Silver72's Avatar
It was what they had. Was going on advice from friends and trying it out. They have it in a heavier 20w-50 weight, no 10w-40.
Silver72 is offline
post #21 of 25 (permalink) Old 07-28-2009, 06:05 PM
what kind of bikes do they have?
right rear set
also
Thanks to dotnetrs
post #22 of 25 (permalink) Old 07-28-2009, 10:26 PM Thread Starter
Silver72's Avatar
Kawi 636, GSXR750(07 i think), GSXR600 '07. Same kinda I4.
Silver72 is offline
post #23 of 25 (permalink) Old 07-29-2009, 10:38 AM
is that what they run in there bikes 20W ?
right rear set
also
Thanks to dotnetrs
post #24 of 25 (permalink) Old 07-29-2009, 11:28 AM Thread Starter
Silver72's Avatar
I think it's all you can get with Rotella.
Silver72 is offline
post #25 of 25 (permalink) Old 07-29-2009, 11:38 AM
wow 20W is some thick sht,
right rear set
also
Thanks to dotnetrs
