No power to anything!!! - 600RR.net
post #1 of 15 (permalink) Old 08-08-2009, 09:58 AM Thread Starter
I have absolutely no power to anything. I took my fairings to do a oil change. Everything started back up just fine, I warmed it up and everything seemed good. Rolled in neutral for about 3 feet and the power to it completely shut off. Nothing happens when I hit the ignition switch, no power to the gauges, the horn and headlights don't work.
Battery reading is good it's just over 13V.
hy3rid is offline
post #2 of 15 (permalink) Old 08-08-2009, 10:05 AM
Moto GSpizzle
B-DubStunts's Avatar
Images: 13
wont start at all now? and its got a good connection?
sounds like the battery is not hooked up...
...just sayin...
Originally Posted by wu_dot_com View Post
and never piss off squidy, or he will picture argue you to death.
Originally Posted by E-NA6CE View Post
Sausage. Yeah! I love sausage!!!
B-DubStunts is offline
post #3 of 15 (permalink) Old 08-08-2009, 10:29 AM Thread Starter
Probably should have mention this but when it shut off i redid the connections to the battery and it started back up. But as soon as I started moving again it shutoff. Now I get nothing.
I just noticed however that as soon as I reconnect the negative side to the battery the RPM needle moves up then back down but nothing else happens afterwards.
hy3rid is offline
post #4 of 15 (permalink) Old 08-10-2009, 12:04 PM
Moto GSpizzle
Images: 13
got a friends bike around? try his battery. if his dont work you might have fried your CPU. did you connect the negative side first?
i might be wrong but thats what it sounds like to me
post #5 of 15 (permalink) Old 08-10-2009, 12:10 PM
CTM_Patron's Avatar
branden giving advice??? what has this world come to??? LMFAO
CTM_Patron is offline
post #6 of 15 (permalink) Old 08-10-2009, 12:20 PM
1ofakindRR's Avatar
^^ Bwhaha. Whores are stupid. We don't give advice.
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
post #7 of 15 (permalink) Old 08-10-2009, 12:24 PM
CTM_Patron's Avatar
and when we do, it tends to be wrong or misleading..LMFAO:all_cohol
post #8 of 15 (permalink) Old 08-10-2009, 12:37 PM
R3DS2K's Avatar
Feedback Score: 6 reviews
when you say the needle goes up and back down. was the key on or off?
any pictures of the battery and connectors. good pictures. from afar and close a up are good
since the bike has been off for a while, what does the battery voltage read now?
R3DS2K is offline
post #9 of 15 (permalink) Old 08-10-2009, 12:44 PM
E-NA6CE's Avatar
Images: 2
Hey, assholes, us whores are smart, sometimes.
Anyway, check to see everything is grounded properly and you're not arcing out somewhere. Secondly, did you check all of your fuses? A fuse should pop before any real damage is done. If you find one busted, replace it and see if it pops again. If it does, then you're arcing out somewhere. If you cleaned your battery posts with a silicone-based cleaner (usually a spray cleaner) then sand that mierda down as well as your terminal connections and hook it back up. Those spray cleaners suck ass and can inhibit current.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #10 of 15 (permalink) Old 08-10-2009, 02:30 PM
Moto GSpizzle
Images: 13
maybe you shoulda asked my advice before you oiled your filter :all_cohol
post #11 of 15 (permalink) Old 08-10-2009, 02:37 PM
CTM_Patron's Avatar
ROTF....can i get some of your expert advice on PAIR removal?:all_cohol
post #12 of 15 (permalink) Old 08-10-2009, 02:44 PM
*BOTM Feb '11, Mar '12*
sincalirider's Avatar
Feedback Score: 27 reviews
Bahahahah, Serg.........
sincalirider is offline
post #13 of 15 (permalink) Old 08-10-2009, 02:48 PM
CTM_Patron's Avatar
LMFAO...it actually wasn't my filter...i jes never bothered sharing. one of the dumb wires on the bazzaz got loose, that's why i could run a whole lap before losing power. the next day when i got it all back together i was having the same problem..then my dumbazz brother comes up and just reconnects the wire, and BAM!!! what a fcuking waste of my BMC...jhahahahaha. oh wells
post #14 of 15 (permalink) Old 08-10-2009, 02:50 PM
Not making yourself out to look like a capable mechanic right now:icon_stud:all_cohol
Bahahahaha
post #15 of 15 (permalink) Old 08-10-2009, 02:51 PM
CTM_Patron's Avatar
Bahahahaha
LMFAO...im not in the business of being a mechanic so i don't care...jhahahaha:all_cohol
