Front brake problem? - 600RR.net
post #1 of 6 (permalink) Old 08-09-2009, 06:01 PM Thread Starter
Hey, seems like I may be having a problem with my front brake. I got my tires changed yesterday (they also scratched my rims pretty bad..) When I stuck it back together it seems as if the front brakes are scraping more than what seems normal, also feels like I have to pull the lever a bit more to get the normal braking power. I took off the calipers again and everything seems to be fine but im still having the problem, any ideas?
The only thing I can think of is they bent my rotor or something maybe?
Curtis is offline
post #2 of 6 (permalink) Old 08-09-2009, 07:22 PM
1ofakindRR's Avatar
Usually that's what it means is that the rotor is warped. One of the only ways to find out is to get a dial indicator that they use for cam lobe lift measurements. Basically, you're gonna want to mount it on something 100% secure and immovable. Then slide the rotor underneath it and spin it. Watch out not to do it between the holes. Then do it on the other side. It should be exactly the same measurements.
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
post #3 of 6 (permalink) Old 08-09-2009, 07:23 PM
1ofakindRR's Avatar
But then again, you should be able to see it with the naked eye if it's that bad...
R.I.P. PHATTY!
post #4 of 6 (permalink) Old 08-09-2009, 08:27 PM
busyychild's Avatar
Feedback Score: 80 reviews
the scraping sound is normal. the pads are rubbing agains the rotors which have the old brake pad material on it. clean the rotors really well. the sound should go away after a while when the pads bed in.
as far as the brake lever feel, try bleeding the brakes for good measure. if nothing changes then you may have a bigger issue.
search for brake bleeding on this forum, there are a few write ups.
as far as cleaning the rotors, get some brake cleaner and a good scrubbing pad. just make sure not to scratch up the rotors.
good luck
busyychild is offline
post #5 of 6 (permalink) Old 08-09-2009, 08:33 PM
1ofakindRR's Avatar
^^ Well he said he knows scraping is normal but he feels it's more than usual.
R.I.P. PHATTY!
post #6 of 6 (permalink) Old 08-09-2009, 08:34 PM
1ofakindRR's Avatar
As for the lever, I agree with Busy. A good bleed should take care of it.
R.I.P. PHATTY!
