FI light and Oil light - 600RR.net
post #1 of 21 (permalink) Old 08-24-2009, 09:05 PM Thread Starter
My bike started to die all of a sudden when riding normal around 4-5 rpms and then also when in really low rpms. It doesn't seem to die untill about 10 mins into riding. It also seems sluggish and slightly jerky. I noticed the FI light is always on. The oil light now blinks twice as well (can't find my manual so I forget the exact meaning) I took everything off and checked the 8 injectors and all were clean and no leaks.
Any ideas? I thought maybe electrical although maybe theres something I forgot.
Worlds Icon is offline
post #2 of 21 (permalink) Old 08-24-2009, 09:10 PM
Chief IronLungs
cbrRedRag's Avatar
Feedback Score: 8 reviews
https://www.600rr.net/vb/showthread.php?t=85319
Hit busters on the head like Vonage
* Im not rude, youre just insignificant
cbrRedRag is offline
post #3 of 21 (permalink) Old 08-26-2009, 09:42 AM Thread Starter
I know about the codes, I was asking about the oil light flashing twice. Two short blinks and off and repeat.
post #4 of 21 (permalink) Old 08-28-2009, 05:36 PM
murphdog1411's Avatar
Images: 94
You never said what year your bike was.....
In my 03 manual it says nothing about checking codes using the oil light. It only says to check and make sure the Oil Pressure Switch is operational.
murphdog1411 is offline
post #5 of 21 (permalink) Old 08-29-2009, 06:56 PM
Drivin2fast99's Avatar
im having the same problem. Two short blinks then repeat.
It dosent seem to affect performance at all though??
Drivin2fast99 is offline
post #6 of 21 (permalink) Old 09-16-2009, 02:51 PM
Map Sensor Vacuum line. Mine came off and I put it back on and reset the codes.
fixed.
post #7 of 21 (permalink) Old 09-16-2009, 06:23 PM
Dr. GoFast's Avatar
did this happen right after an oil change or after a tip-over? if so, could be an air-lock.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #8 of 21 (permalink) Old 09-16-2009, 07:51 PM
okay i just did a motor swap on my 03 600rr and now my oil light comes on and flashes, but only when im at real low speeds and come to a stop, i runs perfect other then that, any suggestions?
txstreetracer1024 is offline
post #9 of 21 (permalink) Old 09-16-2009, 07:55 PM
whats an air-lock are you referring to hydra lock
blue 07 600rr
A22 nesba
urotech is offline
post #10 of 21 (permalink) Old 09-16-2009, 09:19 PM
Dr. GoFast's Avatar
air-lock is when you have air in the oil; just like when you get air in the brake lines. it's not the same as a hydra-lock. it can happen when you don't prime a motor properly after an oil change, or when you bike tips over. it will cause the oil light to come on and your oil level will look higher than it was before. it will eventually work itself out via the breather on the valve cover; but by that point, the damage may already have been done. priming the system is ESSENTIAL if the motor has just been rebuilt and with built race motors (especially with the r6) it's essential for each oil change.
2004 Honda CBR600RR
-Woodcraft rearsets
-Woodcraft Clip-Ons
-Elka 3-Way Shock
-CRG gold levers
-PCIII
-green painted rims
-Tanktredz
post #11 of 21 (permalink) Old 12-11-2009, 09:03 PM
maxboy02's Avatar
fixed.
Drivin2fast, I have the same issue with my 06 RR, 2 blinks on the FI but it runs perfectly. I have looked at the service manual and it shows the MAP as being on the side of the Fuel Tank but I cannot find it to save my life. Is it under the tank, and do I need to remove it to get to the hose?
Also, will I damage my bike riding with this issue?
Sorry to jump in, but thanks for any responses.
maxboy02 is offline
post #12 of 21 (permalink) Old 12-14-2009, 11:04 AM
Check your vacuum hoses for a crack or a loose hose clamp.
qqac is offline
post #13 of 21 (permalink) Old 12-14-2009, 12:45 PM
ccs907's Avatar
located between the throttle bodies, attached to the bottom of the airbox.
It is the item at the very top of the photo attached to the vertical hose of the manifold.
No you will not damage the bike riding like this, but it will run like garbage if the leak gets any worse.
ccs907
ccs907 is offline
post #14 of 21 (permalink) Old 12-20-2009, 10:29 AM
maxboy02's Avatar
Thank you so much, thats very helpful!
maxboy02 is offline
post #15 of 21 (permalink) Old 12-28-2009, 05:39 PM
maxboy02's Avatar
That was it! The hose got disconnected and I just re-attached it and it went away, thanks again!
maxboy02 is offline
The Following User Says Thank You to maxboy02 For This Useful Post:
Ants03 (08-19-2014)
post #16 of 21 (permalink) Old 12-28-2009, 06:47 PM
ccs907's Avatar
Good! Glad to hear it!
Next please! Next in line?
ccs907
ccs907 is offline
post #17 of 21 (permalink) Old 08-19-2014, 01:56 PM
Hey guys I was readin ur post ready good inf0
I havin problems wit my 03cbr600 rr. Do to a shot
It tripped my speedometer an after ridin about a mile oil
Light turns onn help!! I read the code by Putin the kick stand
Down an one light from oil light? No if light ever comes on??
Anybody can help me?? The bike still runs strong an aidles good??
Ants03 is offline
post #18 of 21 (permalink) Old 08-19-2014, 02:48 PM
No fi light ever came on!! Can anybody help??
Ants03 is offline
post #19 of 21 (permalink) Old 08-18-2016, 12:03 PM
Greenzman's Avatar
Can someone repost this picture so that i can see what he is talkin about? i am having this exact problem!
Greenzman is offline
post #20 of 21 (permalink) Old 08-18-2016, 12:09 PM
ccs907's Avatar
You need the location of the MAP Sensor?
ccs907
ccs907 is offline
post #21 of 21 (permalink) Old 09-03-2016, 08:10 PM
I'm having a similar issue. At the track today, power would cut out sporadically and I'd get the FI and oil lights (not blinking.) Then both lights would go away. More often than not it was happening near redline, but it happened down low in the RPM range as well. It would occasionally stall out while I was pulling into the pits.
I put some new rearsets on last night and I'm wondering if I didn't bump a vacuum line somehow in the process. That, or I got bad gas
st33zy is offline
