Engine Questions - 600RR.net
post #1 of 11 (permalink) Old 08-25-2009, 05:06 PM Thread Starter
kevinsheadphones's Avatar
Engine Questions
what does the yellow and white wire connect to?
-------- Want to Buy / Parts list---------
right rear set
rear sprocket +3 525 chain and stock gearing 14 front spkt
also
02 Gixer 600 Parts , its a suzuki .. just tell me what u got
___________________________
Thanks to dotnetrs
dcope17 - infinate719 -
kevinsheadphones is offline
post #2 of 11 (permalink) Old 08-25-2009, 06:39 PM Thread Starter
Question
Anyone ?
right rear set
also
Thanks to dotnetrs
post #3 of 11 (permalink) Old 08-25-2009, 06:47 PM Thread Starter
---cam pulse generator ?
right rear set
also
Thanks to dotnetrs
post #4 of 11 (permalink) Old 08-25-2009, 11:07 PM
murphdog1411's Avatar
Images: 94
Does it have a red connector on it? In the service manual its showing the wire going into the case using the rubber grommet to seal the clutch cover. if it is that, it is for the crankshaft position sensor.
murphdog1411 is offline
post #5 of 11 (permalink) Old 08-26-2009, 11:00 AM Thread Starter
Exclamation
I'm not sure about the red connector, but the wire does go into the case using the rubber grommet to seal the clutch cover.
if it is a crankshaft position sensor, it got damaged. I just got a service manual(my new bible), so i can look into it further and see if that is it.
are there any vendors on dotnet that can give me a good price for a replacement?
right rear set
also
Thanks to dotnetrs
post #6 of 11 (permalink) Old 08-26-2009, 11:08 AM
dcope17's Avatar
Yep, crankshaft position sensor.
I have a good one from an '06 motor if you're interested.
dcope17 is offline
post #7 of 11 (permalink) Old 08-26-2009, 11:25 AM Thread Starter
YES I am interested, thats what year my engine is 06, - how much?
I know that 03 to 06 the RR are really close, but what years should i look for on direct engine parts replacements? ( 05 to 06 )
right rear set
also
Thanks to dotnetrs
post #8 of 11 (permalink) Old 08-26-2009, 12:29 PM
dcope17's Avatar
Idk... $20.
dcope17 is offline
post #9 of 11 (permalink) Old 09-16-2009, 03:17 AM Thread Starter
do you need to reset anything when changing the crankshaft position sensor?
post #10 of 11 (permalink) Old 09-16-2009, 03:37 AM
SHORTSTACK's Avatar
Feedback Score: 15 reviews
no. youll be good just putting it in.
R.I.P. PHATTY
SHORTSTACK is offline
post #11 of 11 (permalink) Old 09-16-2009, 04:24 AM Thread Starter
thanks,
that's what i have been reading.
so far it looks like the only thing is to make sure to put it in correctly.
