motor-ectomy - 600RR.net
post #1 of 3 (permalink) Old 08-31-2009, 12:01 AM Thread Starter
motor-ectomy
Here's the background - 03 CBR600 original motor gave it up o nthe cool down lap at RA in july, found a replacement from a crashed 06 - swapped out the speed sensor (different connector) now here's the problem, I've got a oil pressure light coming on after the engine runs for a few moments, beast has oil and all, sounds fine - anyone know of a difference in the sending unit on the 06 from the 03 that might cause a false? going to take a oil pressure gauge to it soon either way to make sure - any advice is appreciated
twilkinson3 is offline
post #2 of 3 (permalink) Old 08-31-2009, 12:08 AM
ccs907's Avatar
as far as i know that are the exact same. single wire and all. could be a faulty unit or a bad wire or short.
let us know what that oil pressure reading gives you.
ccs907
ccs907 is offline
post #3 of 3 (permalink) Old 08-31-2009, 10:07 PM Thread Starter
80-90 psi while under 100 deg at 6k rpm, I think the pump is working fine, plan of action now I think is swap the sensor out with the original motor one and see if the warning light goes away - after that diving into the wiring harness (ugh)
