Will not Redline! 03 RR. HELP! - 600RR.net
post #1 of 21 (permalink) Old 04-04-2010, 12:56 AM Thread Starter
ZachRR's Avatar
EDIT:
Strange problem and it is not consistent at all. My RR will not redline. It goes to about 13k and then starts hesitating like it isn't getting enough fuel. It will drop down RPM then go up and continue going back and forth like that but refuses to redline.
Went on a ride today, first 4 or 5 pulls it redlined fine. Last 3 or 4 pulls it would go to 13k and start hesitating and stuttering. Doesn't make sense.
Brand new plugs just put in 3 days ago (bike has a lot more power now).
I had a problem similar to this last season...the bike would not go past 9k. And then i had a problem where it wouldn't go past 13k, it would simply stop and refuse to go any further.
To fix that problem i put REDLINE fuel system cleaner through a tank and like magic the bike would redline again! And until now it has been fine. ANY possibilities guys? Thanks, and i know this is confusing....
Please help me out :-(.
Note: Maybe it is my fuel pump? I have an extra fuel pump on hand if that is a possibility of being the case.
Thank you everyone for your help!
Faster, faster, faster...until the thrill of speed overcomes the fear of death.
4 wheels move the body, 2 wheels move the soul.
Mods:::::
Custom dyno tune
Two bro's carbon fiber slip-on
K&N air filter
Power Commander V
520 chain conversion -1/+2
Fender eliminator
Integrated tail light
Flush mount turn signals
Puig double bubble windscreen (Red)
CBR tank protector
CBR grips
Padded rider seat
RR etched passenger seat
All that rollin' on dunlop Q2's
ZachRR is offline
post #2 of 21 (permalink) Old 04-04-2010, 02:12 AM
genequit's Avatar
had a similar problem. bike would reach a certain rpm and get stuck there. got a fuel pump from ebay and its been good ever since. good luck.
genequit is offline
post #3 of 21 (permalink) Old 04-04-2010, 09:21 PM
michaelwood's Avatar
I had a similar, but not the exact problem. One of my battery terminals was loose and it would vibrate at certain RPM's and not make contact.
Current bikes:
2004 CBR600RR (daily rider, to be raced)
2006 CRF450R
1973 CG150 (off road, future restoration project)
1971 CB100 (being restored)
2006 BWS50 Zuma
Bikes of my (recent) past:
2004 Honda Ruckus, completely built, 55mph on the flats, 60 downhill and/or drafting
2007 Kawasaki Ninja 250
2004 Yamaha R6
CBR600RR Mods:
BMC race filter
Jardine slip on
8987 PENSKE triple adjustable shock
STM slipper clutch
Power Commander III
Gear up or go home!!
michaelwood is offline
post #4 of 21 (permalink) Old 04-05-2010, 01:25 AM Thread Starter
ZachRR's Avatar
Yes i think it may be the fuel pump....but i just figured out the whole "with my fiance on the back" thing was a fluke. It does it no matter who is on the bike but it is not consistent! The first couple pulls today it was fine and then started doing it again. Totally confusing!
I guess it could be a battery connector but wouldn't the lights and fuel system shut down too or something.
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #5 of 21 (permalink) Old 04-05-2010, 01:38 AM
If you have an extra fuel pump laying around I would swap it out...a fuel pump as it heats up can and will lose pressure\volume if it has a bad winding in the motor...
how did the plugs look when you pulled them??
spooledcrxb18 is offline
post #6 of 21 (permalink) Old 04-05-2010, 11:16 AM Thread Starter
ZachRR's Avatar
Plugs looked like total crap. All nasty and janked up.
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #7 of 21 (permalink) Old 04-05-2010, 04:58 PM
maverick720's Avatar
This may seem like an odd question but are you using a fuel management system like a PC?
9.92 @ 135.00
maverick720 is offline
post #8 of 21 (permalink) Old 04-05-2010, 10:55 PM
dcope17's Avatar
Are you burning oil? Sounds like possible valve seal leaking.
Bad fuel pump gives a lean mixture leaving the plugs really white and maybe a little white "hard water" looking buildup. Oil into the cylinder give a more gunk nasty black plug.
dcope17 is offline
post #9 of 21 (permalink) Old 04-05-2010, 11:50 PM Thread Starter
ZachRR's Avatar
No fuel management system. Have K&N filter and two brothers pipe thats it. And the bike doesn't burn a drop of oil.
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #10 of 21 (permalink) Old 04-06-2010, 01:25 AM
Can get any pics of them? Or maybe describe em a little better...coloring, "type" of gunk
starting to sound like maybe a spark related issue...does the bike break up or just fall on its face? Does the bike seem to change tone when it hits the "wall" could also be a valve float issue but would be kind of weird seeing how the first few pulls are ok, but I have seen in some cars with worn valve springs that the spring rate will actually change with engine temp...
post #11 of 21 (permalink) Old 04-06-2010, 11:06 AM Thread Starter
ZachRR's Avatar
I had the valves done along with the plugs at a ducati dealership locally. So i couldn't really tell you what they looked like other than that the mechanic said they looked pretty shitty. He didn't really go into detail though. The exhaust smelled like fuel before i got the plugs changed so i knew they were going bad.
The redline factor seems to be linked to how much gas i have in the tank. If i am running on a full tank it will redline, but once it drops to around half tank it will stutter around 13k.
And the bike doesnt really change tone at all. It just sort of hits the 13k or so mark and tries to pull through it but it can't quite do it. It doesn't jerk me or anything, just acts like it doesn't have the fuel to do what it wants to. And if i really stay on the gas i can get it to pull to 14k or even 15k sometimes if i am in a lower gear.
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #12 of 21 (permalink) Old 04-06-2010, 01:49 PM
Gotta run to work but have you checked the fuel vent tube? Ill hit you up more when i get home...
post #13 of 21 (permalink) Old 04-06-2010, 02:42 PM
Derf001's Avatar
Could be a loose gas line or maybe clogged injectors. Try injector cleaner in the gas
2006 Silver 600rr
Yoshimura Rs5 slip on
LP flush mounts
LP rear integrated tail light
Zero Gravity DB
OEM Seat Cowl
Street glo led kit
Derf001 is offline
post #14 of 21 (permalink) Old 04-06-2010, 02:53 PM
bendu's Avatar
My bike had the same problem. I swapped the fuel pump unit with one from ebay. The problem has been gone for 2 years.
bendu is offline
post #15 of 21 (permalink) Old 04-06-2010, 03:51 PM
Cyanide41's Avatar
So if running the FI cleaner worked last time, why haven't you tried it again? If that doesn't work I would try swaping that extra fuel pump in since that seems to be a common cause.
..::JAMES::..
wera #77
'06 GSXR750
'07 CBR600RR
'05 CRF250
'01 SV650
'05 Ducati 749D
'97 CBR 600F3
Cyanide41 is offline
post #16 of 21 (permalink) Old 04-08-2010, 02:18 AM Thread Starter
ZachRR's Avatar
Nope i didn't check the fuel vent tube.
I did run injector cleaner through it again and it didn't help at all.
Just changed the fuel pump tonight, but its too cold to ride and i'm too tired....so news on the outcome tomorrow.
Fuel pump was off of ebay, so who knows!
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #17 of 21 (permalink) Old 04-10-2010, 02:04 AM Thread Starter
ZachRR's Avatar
Ran the tank near empty because i didnt have enough room to redline it. Finally on the last bar of fuel i got some open space and tacked out second gear. Front wheel skipping across the ground all the way to 15k rpm. Woohoo!!!
Fixed!!!!!!!!!!!
Cross your fingers lets hope this pump STAYS good.
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #18 of 21 (permalink) Old 04-13-2010, 12:06 PM Thread Starter
ZachRR's Avatar
Through another 3 tanks....bike redlines and has a lot more power now to boot. ITS ALIVE!
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
post #19 of 21 (permalink) Old 04-13-2010, 03:17 PM
ShiznitForBrains's Avatar
Great News!
2002 CBR600F4i
ShiznitForBrains is offline
post #20 of 21 (permalink) Old 04-14-2010, 11:56 PM
genequit's Avatar
glad to see it worked out for you. another forum member actually suggested this fix to me last year.
genequit is offline
post #21 of 21 (permalink) Old 04-15-2010, 03:01 PM Thread Starter
ZachRR's Avatar
Yea it seems like the most simple explanation is the right one. I looked at some other topics similar to mine and people were saying it might be bad injectors and all of this other crap.
Fuel pump...easy fix lol
Mods:::::
Custom dyno tune
K&N air filter
Power Commander V
Fender eliminator
CBR tank protector
CBR grips
Padded rider seat
ZachRR is offline
