HAveing battery troubles - 600RR.net
post #1 of 7 (permalink) Old 04-05-2010, 10:24 AM Thread Starter
I am new to The Forum circuit, I have a 2005 RR and i am having trouble keeping a charge on the battery, If you pull the positive cable off when the bike is running it dies, what do i need to do? Is it the battery, or is it the bikes charging system?
sambo 623 is offline
post #2 of 7 (permalink) Old 04-05-2010, 10:43 AM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
That is normal will happen on cars to why are you pulling the + cable off the battery ?
Moeman is offline
post #3 of 7 (permalink) Old 04-05-2010, 11:18 AM
Too short to drag knee.
makct04's Avatar
Feedback Score: 11 reviews
Actually Moe, based on my experiences with cages, if you were to disconnect the both the positive and negative the alternator should keep the vehicle running. That is if that system is good.
Check to see if there is a date code on the battery, if its older than a couple years it might have bad cells/acid.
LRRS/CCS AM #521
makct04 is offline
post #4 of 7 (permalink) Old 04-05-2010, 04:53 PM
maverick720's Avatar
You can use a multi meter and put a probe on the negative post and on the frame and check for voltage leaking to ground.
9.92 @ 135.00
maverick720 is offline
post #5 of 7 (permalink) Old 04-05-2010, 04:55 PM
I wonder if autozone's battery tester is compatible with our batteries?
9.92 @ 135.00
post #6 of 7 (permalink) Old 04-05-2010, 08:47 PM
michaelwood's Avatar
should be for the most part.
But did you leave your battery sitting for any amount of time? THey can be toast if you left it sitting uncharged for over one month. They can become weak after sitting for 3 months. Sometimes a good charger, a desulfating model can bring some batteries back, but some batteries, are pressureized gas recombination type, and if left along the pressureized gasses can find their way out over time and lead to battery problems.
If your battery is not sealed you could maybe have someone carefully crack it upen and test the acid or put more in there.
They have our batteries on ebay for @30 shipped, not OEM quality but close enough for the price. Good luck!
Current bikes:
2004 CBR600RR (daily rider, to be raced)
2006 CRF450R
1973 CG150 (off road, future restoration project)
1971 CB100 (being restored)
2006 BWS50 Zuma
Bikes of my (recent) past:
2004 Honda Ruckus, completely built, 55mph on the flats, 60 downhill and/or drafting
2007 Kawasaki Ninja 250
2004 Yamaha R6
CBR600RR Mods:
BMC race filter
Jardine slip on
8987 PENSKE triple adjustable shock
STM slipper clutch
Power Commander III
Gear up or go home!!
michaelwood is offline
post #7 of 7 (permalink) Old 04-08-2010, 05:28 PM
DeathWish's Avatar
'05 should be a sealed battery. My '06 is. And 05 = 06 mechanically.
Wow 3 months out of a motorcycle battery? That sounds like a mechancical wet dream, as small as these batteries are. Mine is on a Tender 6 nights out of the week, if not 7. Not cause it has to be, but because that's how I am.
I don't understand why you are pulling the battery terminal off while the bike is running. From what I understand, the charging systems on bikes are quite weak. Something like .6 amps @ 5,000 RPM. Which means at idle the alternator isn't generating a damn with of any current, so your bike is probably still relying somewhat on the battery to run a lot of the electrical componetry. Further more, I just checked my shop manual, and there is a large warning saying NOT to disconnect the battery while the ignition is turned on, as you run the risk of damaging electrical components. Since your engine is running, the ignition is obviously on. So stop doing that.
**2006 with Repsol kit**
-Full Akra Ti exhaust
-PCIII
-Flush Mounts
-DIY O2 sensor eliminator
-DIY FE
-Tripage Hugger LED mod (SICK!)
-EVAP canister GONE (must-do for aftermarket plastics on CA bikes)
-6k HIDs
-1/+2 520 conversion
-Black chinese rearsets
-Tinted DB windshield
My $.99 DIY O2 (oxygen) sensor eliminator
DeathWish is offline
