Front brake after winter - 600RR.net
post #1 of 7 (permalink) Old 04-05-2010, 10:36 AM Thread Starter
Slyncka's Avatar
So I pulled my bike out this weekend after being stored all winter. I check the front brake and the level will pull almost the whole way into the grip, its not tight at all. I tried pumping it a bit and still nothing, the reservoir on the top is still full as well. There was no damage or anything like that. Im not sure what this could be, any ideas?
Also its an 07 600RR, all stock brakes
Slyncka is offline
post #2 of 7 (permalink) Old 04-05-2010, 10:42 AM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
Time to bleed your brakes
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #3 of 7 (permalink) Old 04-05-2010, 10:50 AM Thread Starter
Slyncka's Avatar
I just changed fluid last season, what do you think the actual problem is?
Thanks for the reply.
Slyncka is offline
post #4 of 7 (permalink) Old 04-05-2010, 11:31 AM
Chris1091's Avatar
Air in your brake lines...
'07 White/Silver 600RR
Chris1091 is offline
post #5 of 7 (permalink) Old 04-05-2010, 11:59 AM
BOTM Winner 07/12
Images: 8
Its hard to say for sure without seeing it. A whole bunch of things could create it but before you fear the worst bleed the brakes then move on from there. Thats the most common issue. Mine were soft when I pulled it out this year too, just bleed them and there fine. I thin it was because I stored it in a unit that wasnt climate controlled. It never got below freezing but it got into the high 30's low 40's for days, then when I wanted to work on it I brought my heater so i think all the heating and cooling effected it, just a guess, but mines fine now.
08'RR
post #6 of 7 (permalink) Old 04-05-2010, 06:49 PM
shiftn3rdon1's Avatar
Did you use brand new fluid? Buy some new fluid (you should anyways) and bleed them properly. You most likely have air in the lines. When your done, wrap a zip tie around the lever and keep it compressed during the night.
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #7 of 7 (permalink) Old 04-08-2010, 05:05 PM
DeathWish's Avatar
I never understood the zip-tie methodology. If you have a good firm lever once you're done bleeding your brakes, and you make the rounds to make sure you don't have any fluid leaks in your system, you are good to go. You're going to be building a tremendous amount of pressure in the braking system for a long period of time (longer than any braking period) if you do this for 10-12 hours over night. I would bleed the brakes, tighten everything up and do the usual rounds to make sure you don't have any leaks. But spongy brakes like you're describing = air in the system.
**2006 with Repsol kit**
-Full Akra Ti exhaust
-PCIII
-Flush Mounts
-DIY O2 sensor eliminator
-DIY FE
-Tripage Hugger LED mod (SICK!)
-EVAP canister GONE (must-do for aftermarket plastics on CA bikes)
-6k HIDs
-1/+2 520 conversion
-Black chinese rearsets
-Tinted DB windshield
My $.99 DIY O2 (oxygen) sensor eliminator
DeathWish is offline
