Brake light won't come on, fuse checked. ** Solved pressure switch ** - 600RR.net
post #1 of 6 (permalink) Old 04-17-2010, 10:13 PM Thread Starter
I've got an '08 model with the Vortex rear pressure switch, brake light won't light up when I hit the brakes, neither front nor rear. Checked the fuse box under the seat, the connection from fuse box to the light, and both front and rear pressure switches. Is there anything else I'm missing? Or am I gonna have to chase down the wires and find the cause?
t-town cbr is offline
post #2 of 6 (permalink) Old 04-17-2010, 10:17 PM
bullshat830's Avatar
is your rear brake super bright red right now? maybe you have too much tension on your pressure switch. try loosening it up.
'06 600RR
check out my build thread!
https://www.600rr.net/vb/showthread.php?t=181895
bullshat830 is offline
post #3 of 6 (permalink) Old 04-17-2010, 10:19 PM
Demented
Posts: n/a
Is the tail light plugged in? You sure you checked the correct fuse and it wasn't blown?
post #4 of 6 (permalink) Old 04-17-2010, 10:21 PM
GREENROCKET's Avatar
i would have to go with a problem with the pressure switch.....
GREENROCKET
GREENROCKET is offline
post #5 of 6 (permalink) Old 04-17-2010, 10:22 PM
tripage's Avatar
Feedback Score: 91 reviews
Unplug the switch and see if it's already activated.. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #6 of 6 (permalink) Old 04-27-2010, 04:41 AM Thread Starter
Yeah, it was pressure switch. Didn't know you could get it too tight
Closed Thread
