Engine bogs out when throttle opened up - 600RR.net
post #1 of 9 (permalink) Old 04-19-2010, 10:05 AM Thread Starter
redz05rr's Avatar
I have an 05 600rr with about 15000km on it and just recently it started to bog out when the throttle was opened up. It happens after riding for about 15 mins or so and seems to happen in every gear. It seems to climb rpm alright when opened up slowly but bogs out bad when opened up quickly and seems worse around 6000 to 7000rpm. Doesn't happen all the time but seems to be happening more often lately. Happened to me for a few seconds last summer about three times but seems pretty consistsnt lately. I've checked fuel lines they look good, any ideas would be much appreciated. Thanks
redz05rr is offline
post #2 of 9 (permalink) Old 04-19-2010, 10:06 AM
PearlywhiteRR's Avatar
hmmmm, maybe sparks?
PearlywhiteRR is offline
post #3 of 9 (permalink) Old 04-19-2010, 11:06 AM
shiftn3rdon1's Avatar
Sounds like your fuel pump man
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #4 of 9 (permalink) Old 04-19-2010, 11:11 AM
jsteckelberg's Avatar
The RPM you mentioned is right around when the second set of injectors kick in. Maybe this is part of the problem? IDK
jsteckelberg is offline
post #5 of 9 (permalink) Old 04-19-2010, 11:39 AM
Yup, and the fuel pump can't keep up with the extra injectors. There have been a few fuel pump threads lately...whats up with that
post #6 of 9 (permalink) Old 04-28-2010, 09:05 PM Thread Starter
redz05rr's Avatar
for checking your fuel pump can you leave a fuel pressure gauge hooked up while you drive to check the pressure when it boggs out? and does anyone know what pressures are suppose to be when the secondary injectors come in? any other options on checking a fuel pump?
redz05rr is offline
post #7 of 9 (permalink) Old 04-28-2010, 09:44 PM
Macho Office Monkey
chadandy12's Avatar
Could be a number of things in my opinion. Seeming its beeing progessing a good guess is fuel pump as said above. But from what my experiances would incline me to think would be plugs and or wires. When an engine gets a bad spark or no spark it will bog on acceleration quite bad and even back fire. Fuel pumps tend to come in and out sometimes ok others not so much and then one day poof its toast you will get nothing. With the amount of miles you got on the bike fuel pump seems a bit premature to go out. Although plugs should not be an issue either seems more reasonable to me. No offence to the others thinking fuel pump you might be right.
08 600rr Orange/Black
https://www.600rr.net/vb/showthread.php?t=144174
Wifes new ride so pumped!!
chadandy12 is offline
post #8 of 9 (permalink) Old 05-03-2010, 01:34 PM Thread Starter
redz05rr's Avatar
Does anyone know how to test the fuel pump?
redz05rr is offline
Old 07-20-2010, 10:46 PM
mkhsupratt
This message has been deleted by Spectre.
post #9 of 9 (permalink) Old 07-23-2010, 12:30 PM
any idea what's causing your problem yet? my bike is doing something very similar. bought new plugs last night but haven't put them in yet.
jknakes is offline
