03 600rr blinker / cluster light problem - 600RR.net
post #1 of 8 (permalink) Old 05-04-2010, 04:58 PM Thread Starter
alexsracing's Avatar
I had installed some ebay mirrors with led blinkers and worked fine, then I got new headlight Assembly's installed them, put back the front fairings and mirror/blinkers, now when I hit the turn signals just the rear ones work and nothing from the front, but the cluster backlight blinks on and off when flashers are activated.
anyone have an idea to what this is? just to test I unplugged both front blinkers and its still doing the same thing
alexsracing is offline
post #2 of 8 (permalink) Old 05-05-2010, 05:55 PM Thread Starter
bump for answer, using as a daily driver cause my car was stolen on monday and I just had liability
post #3 of 8 (permalink) Old 05-05-2010, 06:05 PM
tripage's Avatar
Feedback Score: 91 reviews
Wiring is messed up? Check the mirror manually and make sure they work.. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #4 of 8 (permalink) Old 05-05-2010, 06:06 PM
eriderTX's Avatar
Sounds like a loose connection from the front turn signal
Gig 'em Ags
eriderTX is offline
post #5 of 8 (permalink) Old 05-06-2010, 04:56 PM Thread Starter
thats the weird thing, I unplugged the front blinkers but still get no arrows to flash when rear are blinking and cluster back light still blinks.
is that what is does without front blinkers?
post #6 of 8 (permalink) Old 05-06-2010, 05:59 PM
tripage's Avatar
Do you have led's front and rear signals? Do you have a flasher relay or resistors installed to slow the rate?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #7 of 8 (permalink) Old 05-06-2010, 08:01 PM Thread Starter
there led front blinkers but they worked fine for 3 months
post #8 of 8 (permalink) Old 05-06-2010, 08:10 PM
tripage's Avatar
Stock flasher relay going bad.... This may be why the indicator on the cluster isn't working.. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
