DDM Hid Help - 600RR.net
post #1 of 14 (permalink) Old 05-09-2010, 02:34 AM Thread Starter
DDM Hid Help
I just got my DDM Hid H7 lights in the mail and first thing i do i run into a problem The spacer that the clip goes over when you install the actual light doesn't fit! does anyone know how to help?
Moodoyan is offline
post #2 of 14 (permalink) Old 05-09-2010, 05:36 AM
James Wong's Avatar
Feedback Score: 6 reviews
I don't have the DDM's but I have HID's which are also H7 bulbs. Unless they totally sent you the wrong one's, maybe you have them inserted upside down?
Ride as if there is a tomorrow to live for.
FS: Dainese Wave V1 Neck Armor Jacket
FS: Dainese Torque Pro Out Air Boot (Euro 41)
2007 Honda CBR600rr Black/Silver - Stolen May 10, 2013 - RIP Evolet
2008 Honda CBR600rr Red/Black
James Wong is offline
post #3 of 14 (permalink) Old 05-09-2010, 07:54 AM Thread Starter
That might be the case. but the spacer is a square and i need a more circular one to fit in the bracket.
Moodoyan is offline
post #4 of 14 (permalink) Old 05-09-2010, 08:48 AM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Are you talking about the plastic part that slides onto the base of the bulb ?
As if it is used the dust cover wont fit into the head light housing
If that is the case you do not have to use that part without it you wont harm
anything i did not use it during my install
Moeman is offline
post #5 of 14 (permalink) Old 05-10-2010, 04:48 PM Thread Starter
that is exactly the peice im talking about. without a spacerthe bulb does mot fit securely. what year is your bike?
Moodoyan is offline
post #6 of 14 (permalink) Old 05-10-2010, 04:59 PM
Back in the Day
Moeman's Avatar
Images: 665
I got an 07 the metal base around the bulb has a lip so to speak that lip fits in a gap
in the head light housing itself then the whole asm is held in place with the OEM spring
give it a shot and post up if you got any questions
Moeman is offline
post #7 of 14 (permalink) Old 05-10-2010, 05:02 PM
Lifetime Premium
patg8227's Avatar
i took a pair of side cutters and trimmed three sides and it worked fine
patg8227 is offline
post #8 of 14 (permalink) Old 05-10-2010, 05:07 PM
Vince21's Avatar
samee! im currently in the process of installing my ddm hids aswell..\could anyone tell me for the low/hi beam wires which is positive and which is negative. bike a 06. theres a black and a black with white stripe wire going to the low light, and a black and a black with blue stripe going to the high beam..
06 Sliver RR
-PC3
-Two Bros exaust
-8000k DDM HID's (w.lowbeam switch)
-CF tank gaurd
-Flush Mounts
-Fender Eliminator
-Intagraded Tail Lights
-Pitbull Swingarm Spools
-Led Accent Lights
-Black Windy
-Custom Krazy Eyes
Vince21 is offline
post #9 of 14 (permalink) Old 05-10-2010, 05:08 PM
Back in the Day
Moeman's Avatar
Images: 665
The stripped wire is the + solid Black is the -
Moeman is offline
post #10 of 14 (permalink) Old 05-10-2010, 05:10 PM
Vince21's Avatar
you the man moeman thank you very much for saving the day again!
06 Sliver RR
-PC3
-Two Bros exaust
-CF tank gaurd
-Flush Mounts
-Fender Eliminator
-Led Accent Lights
-Black Windy
-Custom Krazy Eyes
Vince21 is offline
post #11 of 14 (permalink) Old 05-10-2010, 05:32 PM
RashDisaster's Avatar
I have an '06 and I used the spacer from the stock bulb and it works perfectly. You just have to cut the plastic cylinder with the plugs for the spade slips of flush and replace the one that comes on the DDM. There is a sweet youtube video that shows the exact process here :
www.youtube.com/watch?v=JsqB0kTjPM0
or just search: HID Installation CBR on youtube and its the first video.
Silver 2006 600RR
-> DDM HID 55w 8000K
-> Garmin Nuvi 200 Mounted
-> LED Flush Mounts
-> Smoked Wind Screen
-> Michelin Pilot Powers
-> Pro-Grip+Gas Cap CF
-> Adjustable Brake/Clutch Levers
-> Anodized Grips
RashDisaster is offline
post #12 of 14 (permalink) Old 05-10-2010, 09:59 PM
the metal clip will not fit over the spacer. Place the HID bulb inside the headlight and attach the metal clip. the plastic spacer goes inside the rubber seal that fits inside the hole that you have to drill in the access cap. the spacer ensures that the rubber seal is tight inside the hole and it presses against the clip for extra support.
it just keeps everything tight so that moisture doesnt get inside the healight. the HID bulb is H7 so its fits under the clip without the so called spacer adapter that they show in the above video. Dont get confused by the video obove because he used a diffrent setup and spacer.
b.mike23 is offline
post #13 of 14 (permalink) Old 05-10-2010, 10:02 PM
busyychild's Avatar
Feedback Score: 80 reviews
http://i226.photobucket.com/albums/d...c/IMG_7093.jpg
He is correct. It also acts as support for the bulb with the prongs that stick off of it.
busyychild is offline
post #14 of 14 (permalink) Old 05-10-2010, 11:36 PM Thread Starter
So its supposed to be like that? I dont need to mod it at all to fit my '06? because i think you're talking about an 07/08
Moodoyan is offline
