Battery wont hold charge - 600RR.net
post #1 of 15 (permalink) Old 05-09-2010, 05:29 PM Thread Starter
i have a 03 cbr600rr and just bought a new battery for it. when i first installed it the bike started up fine so i rode for about couple of hours went home. couple of hours later tried to started up again and wont start. so i thought maybe its because its a new battery and just needed to be charge 100% so i put it on the charger till its 100%. started up and its fine same story as before after shutting it off wont start back up... this is probably a common problem so if you can direct me to the right thread or help me troubleshoot this itll be very helpful. thanks
millcitycbr is offline
post #2 of 15 (permalink) Old 05-09-2010, 05:48 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
DO the simple tests first so the first test would be to get the battery load tested
any auto parts store such as pep boys, Autozone usually will do that for free
so get that done to know for sure if the battery is no good , decent or excellent
Just because when you bought it it was Brand new does not mean it was a good battery
In my line of work its not a given that the battery would be excellent because it was just bought. The battery gets hooked up to a machine and tested before installing it and i come across a dead one evrey once and a while
Moeman is offline
post #3 of 15 (permalink) Old 05-09-2010, 06:54 PM
you should read my thread that is going on at the moment. i got my battery load tested, then it failed. bought a new battery went riding for a couple hours and died again. so i went to the dealership and got the charging system checked out and they tell me my stator/generator is bad
scorpion2420 is offline
post #4 of 15 (permalink) Old 05-09-2010, 06:57 PM
Back in the Day
Moeman's Avatar
Images: 665
scorpion
If you have a shop manual you can do the test yourself i do not trust dealerships
Moeman is offline
post #5 of 15 (permalink) Old 05-09-2010, 07:57 PM
After you check the generator, dont forget to check the rectifier also..
telescbrman is offline
post #6 of 15 (permalink) Old 05-09-2010, 09:45 PM
it does say how to check the resistance but i also suck at electrical work, so i wanted to double check my readings with the mechanic and it was only 30 bux. im great with mechanical issues but not with electric issues
post #7 of 15 (permalink) Old 05-11-2010, 10:13 PM
Also if you have any high resistance readings make sure to check the connections and the volage drops on the circuits. Typically if you have issues in your charging system you can verify it by looking at output voltages. Make sure to check your powers and grounds as the basics always get people!!!
structure3230 is offline
post #8 of 15 (permalink) Old 05-15-2010, 03:36 PM Thread Starter
it looks like i need a new regulator. should i get an oem or aftermarket one? does it matter?
post #9 of 15 (permalink) Old 05-16-2010, 05:45 PM
depends on how much is a new aftermarket compared to the oem and also if it has the same wire harness connection
post #10 of 15 (permalink) Old 05-16-2010, 06:43 PM
Putty Buddy's Avatar
I would always stick to OE electronic parts unless they are known to have build quality issues (in this case, I know of none). They'll typically come with a better warranty and give you less trouble should you ever need to exchange it.
Molôn Labé!
"Swim 2.4 miles, bike 112 miles, run 26.2 miles. Brag for the rest of your life."
There IS justice in the universe!
Black 2009 600RR ABS
-Akra Slip on
-Hotbodies flushmount signals
-Vincenzo Performance FE
-Custom Tech Spec tank grips
Putty Buddy is offline
post #11 of 15 (permalink) Old 05-19-2010, 09:39 AM Thread Starter
charging system help
im not sure if the regulator or the stator is my problem so i wanted to tested them before i buy anything...im not good with electrical so if there is anyone around MA/NH area is willing to help me out it'll be appreciated.
thanks in advance
post #12 of 15 (permalink) Old 05-20-2010, 02:53 PM
i had the same problem the past two weeks. the regulator went, its pretty rare for a stator to go if you didnt crash it. if you can find a cheap used one to try as a experiment (wish i would of) then you will know. just make sure you disconnect the neg battery cable before you remove or install the new one. my battery voltage apon start up read at 12.3-12.7 while revving around 5k. now im around 13.8
post #13 of 15 (permalink) Old 07-20-2010, 09:28 AM Thread Starter
Replaced the regulator with a new one from honda and after 1-2 hours of riding , its still doing the same thing.any ideas?
post #14 of 15 (permalink) Old 07-20-2010, 12:09 PM
Where are you, around Lowell? Some nestreetriders members might be able to help you out. If it's not the regulator, check the stator (alternator). Test the output with a multimeter. How many miles on the odometer? The brushes in the alternator may be worn down if there are a lot of miles on the bike. Otherwise, it might just be a corroded ground connection somewhere. Start with the main ground point where all the green wires are bolted to the frame and clean and tighten that. Get all the corrosion and oxidation off the wire terminals so you have good electrical contact.
qqac is offline
post #15 of 15 (permalink) Old 07-21-2010, 05:13 AM
Nico's Avatar
...there are no brushes. Otherwise good advise.
Did you get your battery load tested since you had it go flat? Running it that low will kill it in one go.
You may have an issue with your stator windings, just find the plug that has 3 yellow wires in it and measure their resistance (all three combinations possible) it should be 0.1 - 1 ohm, if its any higher you may have an open winding causing the voltage from your r/r to be low.
Pull apart and clean every plug in the charging system, give them a good scrub with a stiff brush and electrical contact cleaner, then pull off the earthing points and do the same to them.
Run the bike up to 5k rpm and measure your charging voltage, it should be around 14V but below 15.5V.
And remember once you have got the correct charging voltage go get your battery load tested again to make sure you don't end up chasing your tail looking for a further fault in the bike that doesn't exist.
Nico is offline
