Need help with my gas gauge - 600RR.net
post #1 of 5 (permalink) Old 05-15-2010, 08:56 PM Thread Starter
xHECKSHERx's Avatar
Feedback Score: 13 reviews
I installed HID's and I think that I may have disconnected something by accident. My gas gauge is flashing now, it starts from the middle then expands outwards and keeps repeating itself. I looked in the search, and I found a thread where this happened to someone else. Someone mentioned that it could be a bad connection to the float sensor. Is this true? Also, where is the float sensor?
Thanks,
Ian
xHECKSHERx is offline
post #2 of 5 (permalink) Old 05-16-2010, 06:39 PM
Putty Buddy's Avatar
The float sensor in part of the pump assembly on most everything. Yes, it is inside the tank. Double check to see if you didn't accidentally pull a pin out of a connector or left something unplugged when you had the body work off.
Molôn Labé!
"Swim 2.4 miles, bike 112 miles, run 26.2 miles. Brag for the rest of your life."
There IS justice in the universe!
Black 2009 600RR ABS
-Akra Slip on
-Hotbodies flushmount signals
-Vincenzo Performance FE
-Custom Tech Spec tank grips
Putty Buddy is offline
post #3 of 5 (permalink) Old 05-16-2010, 08:06 PM Thread Starter
xHECKSHERx's Avatar
Thanks, I will have to take another look at it. Everything runs fine though, just took her on a 200 mile ride with no problems.
post #4 of 5 (permalink) Old 05-16-2010, 11:58 PM
I had the same problem, when i put the main fairing back on the plug that goes into the back of the gauge cluster was not pushed in all the way, it was maybe 75% in, just pushed it all the way in, problem solved!
simwit is offline
post #5 of 5 (permalink) Old 05-17-2010, 03:07 AM Thread Starter
xHECKSHERx's Avatar
Yeah I'm going to mess with it tomorrow. It has to be that connector because I only unplugged 3 connectors when I installed my HID's. Thanks!
