Engine light on. - 600RR.net
post #1 of 9 (permalink) Old 07-30-2010, 02:40 PM Thread Starter
Lifetime Premium
Rated_RR's Avatar
Images: 8
Feedback Score: 42 reviews
Engine light on.
I decided to disassemble my bike to learn the ins and outs of it. Not a complete tear down but i did pull the motor with the wiring harness attatched. I left the exhaust and radiator attatched to the engine as well. Got the whole bike put back together and it fired right up. I turned it off after about 5 seconds. Since it was low on radiator fluid. However i did notice the engine light was on? I double checked and all the vacume lines and wires and everything is pluged in. Someone told me that since i disconected the wires from the secondary injectors, ecu, battery, headlights and recifier i might just need to take itto bonds and have them reset the light. Any thoughts?
Current Rides:
2009 CBR 600RR
2009 CBR 1000RR Repsol
Rated_RR is offline
post #2 of 9 (permalink) Old 07-30-2010, 02:43 PM
Demented
Posts: n/a
Was the light on with the engine running?
Put the bike in neutral, kickstand down, and turn the bike on. What series of codes are flashes from the FI light?
post #3 of 9 (permalink) Old 07-30-2010, 03:01 PM Thread Starter
Lifetime Premium
Rated_RR's Avatar
Images: 8
The light with the pic of the engine was on when running. I will check the flash pattern if any when I get home.
Current Rides:
2009 CBR 600RR
Rated_RR is offline
post #4 of 9 (permalink) Old 07-31-2010, 12:26 AM
Nico's Avatar
And no you don't have to get it 'reset'.
Nico is offline
post #5 of 9 (permalink) Old 07-31-2010, 02:09 AM Thread Starter
Lifetime Premium
Rated_RR's Avatar
Images: 8
This is an 09. When it is in neutral on the kickstand it just comes on with the normal power up then turns off. It will not come on again until i start it then it has two quick flashes multiple times. Do I need to count every set of flashes, every flash or just the two initial ones?
Current Rides:
2009 CBR 600RR
Rated_RR is offline
post #6 of 9 (permalink) Old 07-31-2010, 02:14 AM
Demented
Posts: n/a
Well, of course it wont come on until you turn the engine on again.
MAP sensor malfunction. Lift the tank and remove the airbox. See if you forgot to install the MAP sensor again, if the hose came off, it's unplugged, etc.
post #7 of 9 (permalink) Old 07-31-2010, 02:18 AM Thread Starter
Lifetime Premium
Rated_RR's Avatar
Images: 8
Figured Map Sensor I prob forgot to hook it up I was to focused on everything else plus I threw a BCM in there while it was torn apart. Thanks for the heads up
Current Rides:
2009 CBR 600RR
Rated_RR is offline
post #8 of 9 (permalink) Old 07-31-2010, 02:20 AM
Demented
Posts: n/a
It's always that damn MAP sensor.
post #9 of 9 (permalink) Old 07-31-2010, 05:25 AM
Nico's Avatar
Good to see you got it sorted,
Also, I find most often that the fault occurs with the skin and bone component of a machine rather than the machine itself! Failing that its the damn MAP sensor :)
Nico is offline
