No turn signals or brake light - 600RR.net
post #1 of 9 (permalink) Old 08-01-2010, 09:31 AM Thread Starter
I'm helping a friend out with his 03 CBR 600rr.
His bike has some aftermarket flush mount signals up front and had an aftermarket integrated brake and turnsignal tail light.
His brake light and turn signals do not work.
so I we decided to put the stock tail light and signals back on, thinking it was something wrong with the aftermarket taillight. Nope...
So I check the fuses behind the left fairing and they are good...
His High beams work, No Horn, no turn signals. The rear brake light is on when we put key in "ON" position, but if we hit the lever, either front or rear nothing...
Bike starts and run, Gauge Custer works, headlights on, middle eye works, highbeam works...
Please help!
Any ideas what to check?
'03 Honda CBR 600RR RED
Smoke LP Flushmount, Smoke LED Tail Light w/intergrated Turn Signals, Custom Fender Eliminator, Smoked WindShield, FX Bi-Xeon Projector, DDM HID,
TripageLED White LED Third Eye, Frame Sliders,
Rear Cowl, Acumen DG8 integrated in Gauge, Pazzo Shorty (Black w/Red Tab), Scotts Steering Damper, Mesh Installed in Farins, 05-06 Gixxer Mirrors w/Signal w/Smoked Lens w/Chrome Bulb, Yoshi RS-5 Slip-On Exhaust, Power Command III USB
Future Mods
Adjustable Rear Sets
Tommy600RR is offline
post #2 of 9 (permalink) Old 08-01-2010, 09:34 AM
06silver600_rr's Avatar
Feedback Score: 42 reviews
the fuse behind the battery, and any pinched wires causing a short
Silver 06RR -SOLD
Watsen LED Flush Mounts - Rizoma Grips and Bar Ends
CA Integrated Tail Light - Ohlins Damper
Puig Double Bubble - Akrapovic Carbon Hex Slip-On
DDM 35w 6k HID - OEM Seat Cowl
Black/Black Shorty Pazzo's - OPP Carbon Fiber Rear Hugger
Tripage Pegs, 3rd eye - Vortex Gas Cap
Woodcraft Starter Cover - Power Commander III
BMC Race Air Filter
06silver600_rr is offline
post #3 of 9 (permalink) Old 08-01-2010, 09:43 AM
ProWakeskater's Avatar
fuse behind the battery couldnt be it. Re-check the fuses behind the left fairing. The horn/brake light/turn signals run off the same fuse.
ProWakeskater is offline
post #4 of 9 (permalink) Old 08-01-2010, 09:59 AM Thread Starter
I checked the fused next to battery its still good.
How about relay? Which one of the 3 is it? probably not the far right one, since that is the one for the engine correct?
Future Mods
post #5 of 9 (permalink) Old 08-02-2010, 08:00 AM
Nico's Avatar
Not a relay, have a look at the wiring harness around the fuse, sounds like it has gone open circuit on you.
Have you tried swapping the fuse? sometimes they can look good but still be blown.
Nico is offline
post #6 of 9 (permalink) Old 08-02-2010, 10:15 PM
z537z's Avatar
Feedback Score: 10 reviews
This can also be a ground issue.
If you don't see 12V accross any of these, try it again with the black lead on the bike's frame. If it shows up then, it's the ground, usually something that fell off or opened up.
There's a shared ground wire between many components up front including lights, and possibly the rear as well. The grounding's a little different on the 03s from my 05...
Nico can probably help
__________________________________________
z537z is offline
post #7 of 9 (permalink) Old 08-02-2010, 10:17 PM
DepPravacion's Avatar
had similar issues,
it turned out to be a ground connection problem.
on the left side of the bike there are a set of green wires that gather to a common ground plug. check there for corrosion or signs of a short.
its amazing how many problems you can have and how much trouble it is hunting down a ground prob.
RIP PHATTY
05/08/1980-10/19/2010
VOTE RON PAUL 2012
DepPravacion is offline
post #8 of 9 (permalink) Old 08-02-2010, 11:11 PM Thread Starter
Turn out to be the fuse,
This is exactly what I tried to day... I pulled the old fuse out and put in a new one and everything worked again...
Thanks guys!
Future Mods
post #9 of 9 (permalink) Old 08-03-2010, 03:10 AM
Nico's Avatar
Good to hear mate,
Dep:
That common ground point isn't on the 03,04 just the 05,06 (lucky I bought the 04 eh?)
Nico is offline
