Brake issue... - 600RR.net
post #1 of 7 (permalink) Old 08-04-2010, 10:21 PM Thread Starter
Brake issue...
04 600RR
When I'm stopped, the lever pulls normal. Once I make a full rotation of my front wheel, I have to pull the lever 3 times to build pressure. I've bled the lines, and replaced the MC. The only other thing I can think of is the rotors...which I hope it is not. I cannot find any used, and new ones are $300+
Has anyone else had this issue? And I've also heard 03 and up rotors are all interchangable, is this true? They have different part numbers in most catalogs I've seen.
rbill2k3 is offline
post #2 of 7 (permalink) Old 08-04-2010, 10:25 PM
Demented
Posts: n/a
Rotors are warped if you are having to pump the lever to gain pressure while the bike is in motion.
post #3 of 7 (permalink) Old 08-04-2010, 10:27 PM
tripage's Avatar
Feedback Score: 91 reviews
If you are having to pump I would check your rotors on the 2 pump and see if they are dragging or check your lines for a leak or air
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #4 of 7 (permalink) Old 08-05-2010, 11:43 AM
He's correct. The warped rotor is pushing your Pads/Pistons Back inside the caliper.
Then you squeeze and it just pushs the pads back into position.
That means, your rotors are really jacked up.
HardRacing is offline
post #5 of 7 (permalink) Old 08-05-2010, 11:49 AM Thread Starter
Awesome. are the 03 and up rotors interchangeable? And does anyone have some laying around?
rbill2k3 is offline
post #6 of 7 (permalink) Old 08-16-2010, 10:14 AM Thread Starter
The aluminum mounting bracket was bent 1/8", and with a micrometer and a mallet, I got it straightened within .001". Bike runs great now.
rbill2k3 is offline
post #7 of 7 (permalink) Old 08-18-2010, 12:04 AM
ccs907's Avatar
don't expect it to last bud. i warped up a rotor last year. huck it, it's no good. it'll warp again, believe it.
Replace it.
ccs907 is offline
