need help with frame sliders - 600RR.net
post #1 of 6 (permalink) Old 08-05-2010, 11:53 PM Thread Starter
03cbr-rider's Avatar
I needed to replace the frame sliders on my 03rr as they're shaved to SH#%T from the previous owner. so my problem is I can't get one off, only one slider has a nut at the end. whenever I try to losen the bolt from the side that doesn't have a nut, it gets tighter? pretty sure they aren't reverse thread....... this doesn't make sense? the bolt is bent pretty bad on one side and it doesn't want to get any looser, I feel like if I try harder it'll just strip out the threads in the frame. I was really trying enough to where the bike was starting to slide and lift off the ground so it's not weakness for sure. any suggestions? please don't post if you can't help. if you have any good ideas or experiences then please post.
03cbr-rider is offline
post #2 of 6 (permalink) Old 08-06-2010, 12:07 AM
Chingbo's Avatar
Feedback Score: 6 reviews
well if the bolt gets tighter, maybe you could expoxy the bolt to the run-down slider, so that it doesnt move when you try to loosen the nut..?
_________________________________________
if you can believe it, and can conceive it,
you can achieve it,
period.
Chingbo is offline
post #3 of 6 (permalink) Old 08-06-2010, 12:26 AM Thread Starter
I'm sorry I'm not really understanding what you're saying? to epoxy the bolt the frame slider?
post #4 of 6 (permalink) Old 08-08-2010, 09:14 PM Thread Starter
Bump helps mes
post #5 of 6 (permalink) Old 08-09-2010, 04:35 AM
Nico's Avatar
Can you post up a pic of the issue? I am having a bit of trouble envisioning what your describing. What brand sliders are they?
Nico is offline
post #6 of 6 (permalink) Old 08-09-2010, 12:30 PM
I recall having the same problem. I didn't realize that the engine bolt used to mount the slider can't be undone until you loosen the pinch bolt. Maybe this is what's giving you trouble?
checksix is offline
