08 guage problems - 600RR.net
post #1 of 5 (permalink) Old 08-16-2010, 02:14 PM Thread Starter
08 guage problems
i have a 08 honda cbr and i was going down the rd. and my rpm guage starts going crazy! it like reads right for 1 secound and then it will go to 0 and keeps doing that off and on and ever since that started happening sometimes when i'm accelerating fast it just starts cutting out on me. I'm not even sure where to start @ in fixing this problem any suggestions will help
sixsicsix19 is offline
post #2 of 5 (permalink) Old 08-16-2010, 04:52 PM
z537z's Avatar
Feedback Score: 10 reviews
Sounds like a shoddy signal - start with connectors - make sure they're clean, and securely plugged into each other.
1st, check connectors going into your gauges.
Next, check the two connectors underneath your left cowl/ram air cover.
Then your RPM sensor would be next, but I'm not sure where that lives on an 08 - somebody can probably chime in on that.
If it's not connectors, it's either the sensor itself, or the 12V supply to it. You can check that with a meter once you get there.
__________________________________________
z537z is offline
post #3 of 5 (permalink) Old 08-17-2010, 03:56 AM
Nico's Avatar
No specific rpm signal, I am pretty sure it comes from the cam pulse generator which is an inductive pickup coil. ecu supplies the rpm signal to the gauges.
Check your connections, make sure that the are secure and free from corrosion, after that start looking further back, cam pulse generator ect. May be worth taking it to the stealership at that point.
Nico is offline
post #4 of 5 (permalink) Old 08-28-2010, 08:22 AM Thread Starter
do u know where the cam pulse generator is located? and i do also want to point out that its not just the guages that r screwing up when i get on the gas hard about 50% of the time it will complety stop accelerating then start again. both these problems started happening @ the same time
post #5 of 5 (permalink) Old 08-28-2010, 10:15 AM
Nico's Avatar
Clutch cover, have a look here for a better idea:
Ronayers
Nico is offline
