shifting issue with rear sets - 600RR.net
post #1 of 6 (permalink) Old 10-05-2010, 12:45 AM Thread Starter
OskyATL's Avatar
Okay so maybe this is a double post, but probably put this in the wrong forum anyway.
Originally when I installed my rearsets I had an issue where I could shift gears when the bike was off and the clutch was not compressed. I solved the issue by moving the way to rods were situated and it solved the problem...Now fast forward to today and I simply changed out one of the rods and nothing with the position of it and it began to do the same thing again. I'm trying to solve this asap.
When the bike is off and the kickstand down I can take my hand and cycle through the gears without touching the clutch. I don't know how to solve this issue.
OskyATL is offline
post #2 of 6 (permalink) Old 10-05-2010, 10:59 PM Thread Starter
OskyATL's Avatar
no takers?
OskyATL is offline
post #3 of 6 (permalink) Old 10-05-2010, 11:06 PM
DepPravacion's Avatar
i read your post a few times..
i think you should take a little more time and type it again..im honestly having a hard time understanding what your original problem was, what you did to fix it, and the new problem...
sory i couldnt help besides prompting you to retype the situation.
RIP PHATTY
05/08/1980-10/19/2010
VOTE RON PAUL 2012
DepPravacion is offline
post #4 of 6 (permalink) Old 10-06-2010, 12:10 AM Thread Starter
OskyATL's Avatar
I put some rearsets on the bike. now that I have them on it shifts without having to compress the clutch. Thats basically it. I'm not understanding what I could be doing for it to do that. The pictures show the setup I'm using.
The set up is the same as it has been before. All i did was change out one of the rods for that red one in the pic. I don't understand what could do it...
OskyATL is offline
post #5 of 6 (permalink) Old 10-08-2010, 10:20 AM
tripage's Avatar
Feedback Score: 91 reviews
You don't have a problem, you should be able to cycle through the gears with the bike off and hitting the shifter. That's the way it works. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #6 of 6 (permalink) Old 10-21-2010, 04:03 PM
DeathWish's Avatar
This. If you REALLY wanna get freaky, you can even shift your motorcycle while its moving without the clutch (i'd still use the clutch for first gear though, and down shifts).
**2006 with Repsol kit**
-Full Akra Ti exhaust
-PCIII
-Flush Mounts
-DIY O2 sensor eliminator
-DIY FE
-Tripage Hugger LED mod (SICK!)
-EVAP canister GONE (must-do for aftermarket plastics on CA bikes)
-6k HIDs
-1/+2 520 conversion
-Black chinese rearsets
-Tinted DB windshield
My $.99 DIY O2 (oxygen) sensor eliminator
DeathWish is offline
