Bike will not start, help please!!! - 600RR.net
post #1 of 9 (permalink) Old 10-24-2010, 10:47 PM Thread Starter
My bike has been sitting for roughly 6 mos. with no battery in it. Purchased a brand new one the other day and bike will not turn on.
No lights on dash, no headlights, wont turn over or click.
Battery was hooked up to a tender for a few hrs so i assume its good.
The clock and fuel gauge work when the bike is off, when i turn the key, it all shuts down.
Any help would be greatly appreciated, thanks guys.
yamahabui is offline
post #2 of 9 (permalink) Old 10-24-2010, 10:58 PM
bullshat830's Avatar
have you checked your fuse? you might have a blown fuse!
'06 600RR
check out my build thread!
https://www.600rr.net/vb/showthread.php?t=181895
bullshat830 is offline
post #3 of 9 (permalink) Old 10-24-2010, 11:03 PM
ifiexplode's Avatar
Feedback Score: 7 reviews
When you put your key to the on position nothing happens right? When you go back to the off position does the RPM needle sweep? Grab a multi meter and see if youre getting 12.5-12.7 out of the battery.
2003 cbr600rr
1998 Honda civic with 97 Type R swap.
2007 RMZ 450
ifiexplode is offline
post #4 of 9 (permalink) Old 10-24-2010, 11:05 PM
Demented
Posts: n/a
The fuel gauge is working when the bike is off, as in key not on?
post #5 of 9 (permalink) Old 10-24-2010, 11:39 PM Thread Starter
When i turn the key to the off position the tach needle does sweep, sorry i didnt tell you guys in the original post. When the key is turned to the on position, clock turns off. I cant test any fuses at the moment cause I dont have a fuse tester, will purchase one in the morning. Thanks for all the suggestions so far.
post #6 of 9 (permalink) Old 10-24-2010, 11:41 PM
Demented
Posts: n/a
What year bike? This isn't going to be an issue with the battery or fuses.
post #7 of 9 (permalink) Old 10-24-2010, 11:44 PM
ifiexplode's Avatar
I wouldnt even bother with a fuse tester, Get yourself a multi meter, They can be had for pretty cheap. You can test fuses with it also. Given that your needle sweeps when you go to the off position im betting the battery is only putting out like 8v. I know you said the battery is new, Maybe it dropped a cell.
2003 cbr600rr
2007 RMZ 450
post #8 of 9 (permalink) Old 10-24-2010, 11:54 PM Thread Starter
its a 2007. Man, you guys are quick, thanks for all the inputs. I appreciate it.
post #9 of 9 (permalink) Old 10-25-2010, 04:16 AM
Nico's Avatar
Well this is a cool one...
I assume that all was working as it should when you put the bike into storage?
If so then pull the fairings off and have a look for damage caused by rodents...
Nico is offline
