Bouncing Engine Speed - 600RR.net
post #1 of 17 (permalink) Old 11-01-2010, 02:42 AM Thread Starter
Mistahtaki's Avatar
So I was just taking a casual ride up the mountain and while riding it started feeling like the the bike was bouncing. It felt like the tire had flat spot and it was causing it to be bumpy. Then I notice that the rpm needle is bouncing while I was keeping a steady throttle. I pulled over and I let it rev in neutral and it sure enough it was bouncing up and down like the fuel was cutting off and switching back on really quickly. The higher the rpm the more it bounced. So I made my way home right after and while going down the mountain it went away and hasn't came back since. Could it be that the fuel injectors were getting clogged or a loose battery terminal?
Mistahtaki is offline
post #2 of 17 (permalink) Old 11-01-2010, 02:44 AM
Demented
Posts: n/a
Try removing your power commander and see if the problem continues.
post #3 of 17 (permalink) Old 11-01-2010, 02:58 AM Thread Starter
Mistahtaki's Avatar
I dont have it on.
post #4 of 17 (permalink) Old 11-01-2010, 03:00 AM
Demented
Posts: n/a
Ok. What mods are on the bike and what has been done recently? What year?
post #5 of 17 (permalink) Old 11-01-2010, 03:08 AM Thread Starter
Mistahtaki's Avatar
04
Slip-on w/ mid pipe
only mod thing that can possibly affect it
post #6 of 17 (permalink) Old 11-01-2010, 03:16 AM
Demented
Posts: n/a
How many miles, and have you ever changed the clutch discs? Will the RPM's continue to bounce when you pull the clutch in?
post #7 of 17 (permalink) Old 11-01-2010, 03:33 AM Thread Starter
Mistahtaki's Avatar
16k and the rpm needle was bouncing while i was holding a steady throttle. When it was idling it sounded choppy. Then after riding about 5 miles down the mountain it just disappeared.
post #8 of 17 (permalink) Old 11-01-2010, 03:41 AM
Demented
Posts: n/a
Idling with or without the clutch engaged?
post #9 of 17 (permalink) Old 11-01-2010, 03:49 AM Thread Starter
Mistahtaki's Avatar
in neutral without clutch
post #10 of 17 (permalink) Old 11-01-2010, 11:06 PM Thread Starter
Mistahtaki's Avatar
So.....anything?
post #11 of 17 (permalink) Old 11-01-2010, 11:11 PM
Demented
Posts: n/a
How about with the clutch disengaged?
post #12 of 17 (permalink) Old 11-02-2010, 01:54 AM Thread Starter
Mistahtaki's Avatar
It happened with the clutch disengaged.
post #13 of 17 (permalink) Old 11-02-2010, 02:05 AM Thread Starter
Mistahtaki's Avatar
and engaged
post #14 of 17 (permalink) Old 11-02-2010, 06:43 AM
Nico's Avatar
Have you got any DTCs?
Nico is offline
post #15 of 17 (permalink) Old 11-02-2010, 04:06 PM Thread Starter
Mistahtaki's Avatar
nope ........
post #16 of 17 (permalink) Old 11-02-2010, 09:50 PM
Nico's Avatar
Vacuum leak in the fuel reg?
Nico is offline
post #17 of 17 (permalink) Old 11-10-2010, 06:18 PM
Images: 3
I have had a similar problem...engine bounces when I hold a steady throttle only when holding RPMs at 6-7 and up engine revs up fine when throttle is wide open or when riding I dont notice any loss of power have slip on and air filter
cbr600.rr is offline
