lil oil leak - 600RR.net
post #1 of 8 (permalink) Old 11-21-2010, 10:38 AM Thread Starter
lil oil leak
i currently have a lil oil leak on my bike. it's coming from a screw on the case cover my question is if i put gasket sealer on the screw and a lil on the rim will that stop the leak? if you have any other suggestions please let me know. thank you
I rather die on my feet than live on my knees
I rather be judged by 12 than carried by 6
jling2967 is offline
post #2 of 8 (permalink) Old 11-21-2010, 10:40 AM
tenjin's Avatar
Do not apply it to the screw, that will make it a pita to get the screw off / put and risk you breaking it ....
do it right, remove the cover and apply gasket sealer propler on gasket surfaces.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 8 (permalink) Old 11-21-2010, 11:29 AM Thread Starter
cant i took a crash with no cut frame sliders the one that replaces the bolt to the engine cover now the screw hold outer is dented in a lil.
post #4 of 8 (permalink) Old 11-21-2010, 12:31 PM
Demented
Posts: n/a
Replace all of the broken stuff and fix it right. If you can't get the bolts off right, cut them off. Pull the cover off then get the stud of the bolt out. Then do yourself a favor, cut a hole in your fairings and use no cut sliders.
post #5 of 8 (permalink) Old 11-21-2010, 07:06 PM
Nico's Avatar
If you go doing a half arsed job now you will only regret it down the track, and no just putting honda bond on there won't work.
Remove the cover, replace it if its damaged (good excuse for woodcrafts'?), along with the damaged bolts and get cut sliders.
Nico is offline
post #6 of 8 (permalink) Old 11-21-2010, 09:09 PM Thread Starter
It's the Clutch cover not the alternator and I already got the woodcraft case cover I'll take the thing apart later on
post #7 of 8 (permalink) Old 11-21-2010, 09:12 PM
Demented
Posts: n/a
Doesn't really matter if it's the stator or clutch cover, or if you already have a woodcraft case cover. Spend the time and fix it right or it will wind up costing you even more money.
post #8 of 8 (permalink) Old 11-22-2010, 08:04 AM Thread Starter
thanks for the advice
