Electrical Problem:Gauge and lights not working - 600RR.net
post #1 of 13 (permalink) Old 11-21-2010, 09:13 PM Thread Starter
Rode to school one morning with no problems but when i turned it on to go home i noticed the gauge wasn't working, the only part that worked was the high beam light and the clock. I checked out all my lights, headlights working fine but all the turn signals were out. The brake light worked at first but then stopped after a few minutes. The bike started and rode fine it was just the lights out. Could this be loose wiring or a blown fuse? I have no idea so i could definitely use some help if you guys have any ideas. Thanks
StreetShark07 is offline
post #2 of 13 (permalink) Old 11-21-2010, 09:14 PM
Demented
Posts: n/a
Check your fuses and then search for the wire fault that caused the fuse to blow.
post #3 of 13 (permalink) Old 11-23-2010, 03:56 PM Thread Starter
Thanks i found which fuse it was. So the fuse blew because of a problem in the wire? Sorry dont know much about this.
post #4 of 13 (permalink) Old 11-23-2010, 03:58 PM
Demented
Posts: n/a
Yes. A short in that circuit will cause the fuse to blow, as that is what they are for.
post #5 of 13 (permalink) Old 11-23-2010, 06:57 PM Thread Starter
Thanks for the info. I narrowed it down to the front right turn signal. Unplugged it and everything else worked fine. Now just need to figure out where the problem is in the connection.
post #6 of 13 (permalink) Old 11-24-2010, 06:45 AM
Nico's Avatar
I wouldn't even bother, just replace it if you have narrowed it down to the turn signal.
Nico is offline
post #7 of 13 (permalink) Old 11-25-2010, 07:18 PM Thread Starter
so i would have to replace the whole turn signal?
post #8 of 13 (permalink) Old 11-25-2010, 07:20 PM
Demented
Posts: n/a
Figure out what the problem is with the turn signal. Chances are it's an issue in the wiring that can be easily fixed.
post #9 of 13 (permalink) Old 11-25-2010, 07:24 PM Thread Starter
Okay thanks. Thats what i thought and didnt want to have to buy all new turn signals lol. This whole problem started after someone knocked over my bike
post #10 of 13 (permalink) Old 12-18-2010, 02:04 AM
mate i have the same problem what fuse was it that u had to replace
glnoak is offline
post #11 of 13 (permalink) Old 12-18-2010, 03:43 AM
Nico's Avatar
Do you know where to find your fuses?
What year is your bike?
Nico is offline
post #12 of 13 (permalink) Old 12-23-2010, 03:47 PM Thread Starter
Mine is a 07 and is under the seat. I think the 06 and under ones are behind the left fairing but im not sure.
post #13 of 13 (permalink) Old 12-31-2010, 08:37 PM
ifiexplode's Avatar
Feedback Score: 7 reviews
Yes 06 and under the fuses are behind the left mid fairing.
2003 cbr600rr
1998 Honda civic with 97 Type R swap.
2007 RMZ 450
ifiexplode is offline
