Battery removal problems - 600RR.net
post #1 of 6 (permalink) Old 01-13-2011, 01:45 PM Thread Starter
Hi, Can anyone help?
I cant remove the battery from the tray. It will come so far up, but then wont budge anymore.
thoughts please?
Thanks in advance
Nathan
Costello is offline
post #2 of 6 (permalink) Old 01-13-2011, 01:48 PM
tripage's Avatar
Feedback Score: 91 reviews
Guessing it's hitting the subframe cross member?
Use a flat head screw driver to tweak it back a little bit and then you can pull up on it..
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 6 (permalink) Old 01-13-2011, 01:54 PM Thread Starter
Thanks, yeah it does look like that is causing it. I only want to remove it so i can thread through the small gap some permannent battery connector terminals.
Being my first bike and not mechanically minded at all, was not sure how much pressure to apply, but will give it a go?
Have you experienced this?
Costello is offline
post #4 of 6 (permalink) Old 01-13-2011, 02:00 PM
tripage's Avatar
Yes, but only because of rerouting of wires in the battery tray.. What year do you have?
Is it a stock battery? Had a customer that had a seadoo battery in his bike, didn't fit at all..
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #5 of 6 (permalink) Old 01-13-2011, 02:06 PM Thread Starter
I can only assume its a stock battery. I have a 2003.
Costello is offline
post #6 of 6 (permalink) Old 01-13-2011, 04:52 PM
Lifetime Premium
I have that same problem. You kinda need to angle towards the positive. Good luck hopefully that works for u.
Midnight is offline
