Chain making strange noise - 600RR.net
post #1 of 17 (permalink) Old 01-15-2011, 05:47 PM Thread Starter
Thats Clutch's Avatar
Every tire rotation my chain makes a grinding noise at a certain point. When im on the back break I can feel it through the pegs rubbing. I think it might have started when I adjusted the chain. I measured the chain sag and it is right.. I also roughly checked out the allignment and it looks ok.. I even cleaned the chain and re lubed and its still going on.
Any Ideas?
Thats Clutch is offline
post #2 of 17 (permalink) Old 01-15-2011, 07:40 PM
*BOTM Feb '11, Mar '12*
sincalirider's Avatar
Feedback Score: 27 reviews
Chain should be loose enough to touch the swingarm as far as slack goes. You could be binding from misalignment. Seems ok and actually ok can be very different. If I were you I would either buy a wheel alignment tool from the WERA vendor;
http://forums.13x.com/showpost.php?p...1&postcount=29
Or buy a chain adjuster like the Gilles or Lightech one. That way you know your wheel is straight.
sincalirider is offline
post #3 of 17 (permalink) Old 01-15-2011, 07:54 PM Thread Starter
Is there an easier way that doesnt involve alot of money. I have heard maybe string or straight pipe to lign up front and back?
post #4 of 17 (permalink) Old 01-15-2011, 08:05 PM
I guess you could make your own from straight pipe. You would have to be 100% sure that the pipe is true. I don't know if you have a machine shop near you but I'm sure they would have something you can use.
post #5 of 17 (permalink) Old 01-15-2011, 08:36 PM Thread Starter
I have some straigt pipe that I am using for a roll cage I will try that. Its pretty true.
How do you look back on threads you have commented on?
post #6 of 17 (permalink) Old 01-15-2011, 08:43 PM
Search-Advanced Search
post #7 of 17 (permalink) Old 01-15-2011, 09:02 PM
50 bux says it is the normal sound the chain makes and you are over thinking it.
put it up on a stand, turn the wheel a few times, make sure the rear sprocket isnt to one side of the chain. The alignment markers are a suggestion. I go by what the chain actually does on the sprocket.
2008 Liquid Silver CBR600RR
Purchased 10/25/2008, Totaled 10/28/2008 by the dealer
New 2008 Liquid Silver CBR600RR....delivered 10/30/2008
bms231 is offline
post #8 of 17 (permalink) Old 01-15-2011, 10:55 PM
MikeyP's Avatar
Feedback Score: 10 reviews
Buy some calipers and measure the axle distance on each side for chain adjustment. You can get a set for $20-25...that's what Mikey does
2008 CBR 600RR #1 (Graffiti) street
2008 CBR 600RR #2 track
CMRA #599
Originally Posted by MikeyP View Post
Unfortunately bikes fall over. It's in their nature.
It's our job to keep them upright, but we are only men.
MikeyP is offline
post #9 of 17 (permalink) Old 01-16-2011, 02:27 AM
crash277's Avatar
http://www.motionpro.com/motorcycle/partno/08-0048/
Originally Posted by nutcore View Post
Duct tape is like the Force, it has a light side, a dark side and it binds the universe lmao
crash277 is offline
post #10 of 17 (permalink) Old 01-16-2011, 02:28 AM
crash277's Avatar
or.. to be really fancy...
http://www.ducatidesigns.com/inc/sdetail/2133
crash277 is offline
post #11 of 17 (permalink) Old 01-17-2011, 01:13 AM
TribalCBR06's Avatar
Images: 13
The alignment is most likely off. Did you also lube it?
Mine has always had that chain noise even when I just bought the bike. But to be safe make sure your chain is properly aligned and maintained. Borrow a rear stand from a friend and put the rear wheel up to test it further.
* * 600RR Ex-Track Junkie * *
Current bike - Yamaha Liquid Silver R1
- Competition Breeds Excellence -
TribalCBR06 is offline
post #12 of 17 (permalink) Old 01-17-2011, 01:31 AM
This is the string method:
http://www.motorcyclistonline.com/ho...els/index.html
Ive read people swearing by this method. Good luck
socal_cbr is offline
post #13 of 17 (permalink) Old 01-17-2011, 01:34 AM
Hey Sincali what part of the swingarm should it be touching? Where do you check?
post #14 of 17 (permalink) Old 01-17-2011, 02:55 AM
It should be touching the swingarm near the front behind the rearset. So that if you put force on the chain it will barely touch it. Its not an exact measurement, but it will easily get you within "range".
post #15 of 17 (permalink) Old 01-17-2011, 03:15 AM
Thanks Sin
post #16 of 17 (permalink) Old 01-24-2011, 04:47 PM Thread Starter
Soo I measured with calipers and it was pretty dead on. I asked a Honda mechanic and he said it sounds like the tire. He said a lot of times new riders will slide out the back tire and create flat spots which makes that noise. I looked and no noticeable flat spots.
It worries me I dont know what to do.
post #17 of 17 (permalink) Old 01-24-2011, 08:07 PM
Nico's Avatar
Does it make the sound with the bike on a rear stand and spinning the tyre by hand? If so it's obviously not the tyre!
If you can get a video that you can clearly hear the sound you are talking about that may help.
Also carefully inspect your chain and ensure that every link in it isn't binding, particularly at the master link (it may have been over riveted) they will be a little stiff due to the o-rings but they shouldn't be binding.
Nico is offline
