Spark Plug guide/check. Post pic for a review - 600RR.net
post #1 of 16 (permalink) Old 01-15-2011, 08:47 PM Thread Starter
kidnplay01's Avatar
Post Spark Plug guide/check. Post pic for a review
Ok guys i havent seen anything on here about spark plug conditions guide etc.
So im hoping the mechanics on here and the guys that know a lot of such things, folks with issues, want a diagnosis can post a pic on here and you the technician/expert can give a review.
And also I/We can all learn from it so we can then in time be able to tell the issues behind the art of Spark plugs diagnosis.
Also a guide to go by
http://www.motorcycleinfo.co.uk/reso..._condition.jpg
Install Guide
https://www.600rr.net/vb/showthread.php?t=221626
I will start first but stating looking at the below pic/guide i just have a worn out spark plug and thats about it?
Pics
Ohlins- Fork Springs, Shock, S.D, UES Kit 20mm, PCIII, Velocity Stack mod, RS-5 C.F Yoshi, Dynoed, K&N Air Filter, Cox Radiator Guard, Powers Race Railz mod, MOTY Battery, Pazzo Levers, Harris Grips, Stomp Grips, Ram mounting, Custom Fairings, Custom led gauges, C.F -Hugger-Sprocket cover,Exhaust,Heel, Chain, Engine,& clutch guards. Trippage led pegs, 520 Conv, -1 +2 Superlight Sprocket, Comp werkes FE, Dunlop Q2's, EBC Kevlar Heavy Duty Clutch/Springs, Vesrah RJL Pads,Braided brake lines
kidnplay01 is offline
post #2 of 16 (permalink) Old 01-15-2011, 08:57 PM Thread Starter
kidnplay01's Avatar
Guide as a pic
post #3 of 16 (permalink) Old 01-16-2011, 02:18 AM
How many miles on the plugs in the pics you took ?
COBRA90GT is offline
post #4 of 16 (permalink) Old 01-16-2011, 03:10 AM Thread Starter
kidnplay01's Avatar
50,000km- 32,000miles
post #5 of 16 (permalink) Old 01-16-2011, 10:11 AM
BOTM Winner 03/13
Sun-Zoom-Spark's Avatar
Images: 175
Originally Posted by kidnplay01 View Post
Guide as a pic
That is excellent, thanks man!
32,000 miles is when they are supposed to be replaced as per the service manual but I would've expected that to be a reasonably conservative estimate for a bike running within normal a/f limits. I suppose they are also to be checked at 16k as well though, and replaced if neccessary.
Sun-Zoom-Spark is offline
post #6 of 16 (permalink) Old 01-22-2011, 07:52 AM
Nico's Avatar
Hard to tell from a close up pic cause the flash washes out any colour it has...
A normal plug will have a very thin and dull coating over it that has a slight brown / orange cast to it, the electrode and bridge should not have any pitting however minimal (barley noticeable) curvature or rounding off on the very corner of the electrode is normal after several (~25) thousand miles, this is caused by the metal of the electrode being deposited onto the bridge by the spark and will generally happen at the edges. Any damage or easily noticeable deformation of the electrode or bridge; cracking (sometimes seen as a line of carbon) of the insulator, or heavy deposits on the plug is not normal,
Anything else is not normal and may point to an issue with the engine or fuel if the plugs are relatively new.
kidnplay: IMO what you have there is normal wear, however (and its certainly nothing to be worried about) there appears to be marginally excessive carbon build-up which may either indicate that the plugs should have been replaced (at a guess) around 5-10k miles ago and that your bike has seen a large number of miles under relatively rich conditions - do you normally ride at low rpm (less than 5k) or maybe wait a while to get it dynoed after you started your performance mods?
Nico is offline
post #7 of 16 (permalink) Old 01-23-2011, 04:22 AM Thread Starter
kidnplay01's Avatar
Your prob dead on about the wear, but i modified (slippon, velocity stack, air filter, PCIII) it 2008, about 3 months later had the dyno. It backfired a bit back then, and as soon as dynoed stopped.
Not exactly something to simply just check on the odd chance.. :)
post #8 of 16 (permalink) Old 01-23-2011, 06:05 PM
Nico's Avatar
Nope not really :)
Nico is offline
post #9 of 16 (permalink) Old 02-14-2011, 08:02 PM
tab112302's Avatar
Sorry about the crappy shots, I will take more in better light later. It looks like normal wear on them, but I don't know crap about reading them. The dealership I bought the bike from said they replaced them before I bought it so they have about 17k miles on them. I just decided to change them while I was doing other stuff to the bike and had it torn down, also to get it back close to the 32k mark as I am currently at 37,646 miles.
#1
#2
#3
#4
tab112302 is offline
post #10 of 16 (permalink) Old 02-14-2011, 08:08 PM
v-tec crx's Avatar
Feedback Score: 10 reviews
^impossible to tell anything from those pics
I am from CANADA, the land of poutine, back-bacon and GOOD BEER!!
2012 STREET BIKE OF THE YEAR
v-tec crx is offline
post #11 of 16 (permalink) Old 02-14-2011, 08:13 PM
tab112302's Avatar
Yeah that's why I said I would get better ones later when there is good lighting but figured I would post these just in case anyone saw anything major.
post #12 of 16 (permalink) Old 02-15-2011, 02:14 AM
Nico's Avatar
They look ok... very hard to tell anything though... they should have a light brown appearance...
Nico is offline
post #13 of 16 (permalink) Old 02-15-2011, 12:14 PM
tab112302's Avatar
Updated with better pics. Now that I actually looked at them in good lighting they look a little worse than I thought. I had only seen them in the crappy lighting of my garage. And as far as performance mods go I have none as of yet. I am waiting on an exhaust, PC3, and the money to get it tuned before installing/buying anything.
post #14 of 16 (permalink) Old 02-15-2011, 01:00 PM
Nico's Avatar
Number 1 is stuffed, to many deposits.
Number 2 is stuffed worse than number 1... same reason
Number 3 is the best of the lot, but is at the end of its life.
Number 4 is marginally worse than number 3
Number 2 seems to have been running a little rich, and number 1 almost looks like it got to hot at some point...
All in all though they just look like plugs that have had a good life and need replacing, nothing really wrong with them
Nico is offline
The Following User Says Thank You to Nico For This Useful Post:
tab112302 (02-15-2011)
post #15 of 16 (permalink) Old 02-15-2011, 01:41 PM
v-tec crx's Avatar
#1
#2
#3
#4
Much better pics... i would say they look normal depending on their age
#2 does apear to have a bit more carbon build up
The Following User Says Thank You to v-tec crx For This Useful Post:
post #16 of 16 (permalink) Old 02-15-2011, 02:13 PM
tab112302's Avatar
Thanks for the feedback guys. (Do I even need to say it now that we have a thanks button?)
