Bike Wont Start - No Fuel No Spark - Pleaase Help - 600RR.net
post #1 of 9 (permalink) Old 01-29-2011, 07:31 PM Thread Starter
Hello. My bike was sitting idle for about a year. I'm now trying to get it going but it won't start. I replaced the plugs, oil, filter, fuel, battery, etc... It turns over but doesnt fire up. It doesnt sound like the pump is priming. I check the plugs to see if they were sparking and nothing. I double checked the fuses and all wiring harnesses too. Does anyone know what the issue could be?
tbfivel is offline
post #2 of 9 (permalink) Old 01-29-2011, 09:54 PM
jasonb's Avatar
Images: 7
Fuel pump Relay???
2006 CBR 600rr All BLACK- SOLD 41,000 miles...
2011 Bmw S1000rr YELLOW
jasonb is offline
post #3 of 9 (permalink) Old 02-01-2011, 07:33 AM
Nico's Avatar
Could be a multitude of things, first things to check would be the engine stop relay - this will kill both the coils and the fuel pump... did you check you FI fuse down next to the battery? Did you look for corrosion at the contacts?
Nico is offline
post #4 of 9 (permalink) Old 02-03-2011, 12:26 PM
same issue here, let me know if you get this resolve. although i think something might be up with my engine...
wir3tap is offline
post #5 of 9 (permalink) Old 02-07-2011, 08:51 PM
doofiep007's Avatar
check the 3 relays on the left side of the motor, with the key on 2 of the three will click over the other is the fan relay(one of the relays will turn off after about 3 seconds....that's the fuel pump prime)
doofiep007 is offline
post #6 of 9 (permalink) Old 02-07-2011, 10:18 PM
tenjin's Avatar
BAS, Bank angle sensor
Ep if you had the front end off or were messing with wiring.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #7 of 9 (permalink) Old 02-13-2011, 04:37 PM
dickturpin 1976's Avatar
same problem here cant hear the fuel pump priming, just fitted some led plate lights earlier today, my bike has been fine, been out on it a few times no issues, just gone to start it and no sound coming from the fuel pump and will not start. its been heavily raining also and my bike didnt have a cover on, dont know if rain has got in somewere and blew something or what. the led plate lights i fitted are working fine too so it wouldnt be anything to do with that would it idk.
take no notice of my post above just figured it out....... my kill switch! PHEEEEEEEEEEEEEEEEEEEEEEWW!!! i never use the kill switch but just this time i did, thats 2 dumb incidents today!
dickturpin 1976 is offline
post #8 of 9 (permalink) Old 02-28-2011, 09:23 PM
i had same issue and all it took for me was unplugging my gauges and plugging back in. i also unplugged the two connectors that go to the headlights after that it started fine.
muzzy12r is offline
post #9 of 9 (permalink) Old 03-01-2011, 07:19 AM
doofiep007's Avatar
fyi the gauges do not control the engine
