Seized engine teardown - 600RR.net
post #1 of 13 (permalink) Old 02-21-2011, 07:24 PM Thread Starter
dcraige's Avatar
2003 600rr, It only had about 7k miles on it an the engine was running fine until I went to start it one morning and it seized during start up. I finally got around to pulling the head and it looks like it full dirt? There is some light scratches on the bottom part of the cylinder walls but besided that everything else looks ok. Should I clean this up and try to run it or replace the whole engine? What would cause this to happen? Thanks.
https://www.600rr.net/vb/showthread.p...40#post2090940
Name:	2011-02-21 15.40.46.jpg
ID:	18991   Click image for larger version
Name:	2011-02-21 15.41.15.jpg
ID:	18992   Click image for larger version
Name:	2011-02-21 15.41.26.jpg
dcraige is offline
post #2 of 13 (permalink) Old 02-21-2011, 08:52 PM
Was there any coolant in there when you pulled the head off??
Its hard to tell from the pics but I dont see how dirt would get in there.
Either way if there are ANY scratches in the cylinder wall (enough to catch your fingernail on) that block needs to be bored and honed out with larger diameter pistons installed. the scratches will make it impossible for your piston rings to seal properly.
Your best bet, beeing how tight these engines are, is to find a replacement.
TEAM BLACK
09 CBR600RR
Security System: S&W 4013TSW
Exodus is offline
post #3 of 13 (permalink) Old 02-21-2011, 09:16 PM Thread Starter
dcraige's Avatar
I cleaned things up a bit and took a few more pics. That one pic is the worst of the vertical scratches so they arent too bad. Nothing I can feel.
The stuff in there was powder dry. My guess is a bunch of flaked off carbon? The intake runners were super dirty too. I'll try to get some pics of that later.
Name:	2011-02-21 17.56.18.jpg
ID:	18996   Click image for larger version
Name:	2011-02-21 17.56.53.jpg
dcraige is offline
post #4 of 13 (permalink) Old 02-21-2011, 10:46 PM
how many miles on that motor? You can still see the crosshatch... only reason im asking.
TEAM BLACK
09 CBR600RR
Exodus is offline
post #5 of 13 (permalink) Old 02-21-2011, 10:51 PM
unanswered600's Avatar
looks like he did that, the horizontal-ish scratches go over the vertical, not under
unanswered600 is offline
post #6 of 13 (permalink) Old 02-21-2011, 10:52 PM
tripage's Avatar
Feedback Score: 91 reviews
May want to get them all cleaned up while you have it apart. If there was ever a time to do it now is that time.
You definitely want the rings to have a good seal so you don't have to do this over again. Had some bad scoring on mine and got it bored+1 and new pistons/rings.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #7 of 13 (permalink) Old 02-21-2011, 11:53 PM
03cbr-rider's Avatar
in your first couple of pictures it doesn't look like carbon build up. carbon deposit is usually always black and gummy not brown and dry looking like those cylinders were. what did your valves look like? I'm only assuming because I used to bore out manifolds and throttle bodies etc. and I've never seen carbon build up that was brown and dry looking like that. Exodus brings up a very good point though, it could be coolant. your third picture almost looks like it has a green hue towards the left flaky piece, that might be something to look into for sure. it could have been just a bad gasket and coolant was leaking through causing the build up.
03cbr-rider is offline
post #8 of 13 (permalink) Old 02-22-2011, 07:26 AM
Nico's Avatar
I've never seen anything like that before.... And I would have expected coolant to show its head by cleaning the crap out of the cylinder, not turning to 'dirt'...
If it was coolant, at the very least you probably want to get the head crack tested and a re-hone - depending on how worn the bores are.
Nico is offline
post #9 of 13 (permalink) Old 02-22-2011, 11:26 AM Thread Starter
dcraige's Avatar
Here are some pics down the intake runners. Alot of crap on the valves. I was thinking the dirt may be coolant but all 4 cylinders had the same stuff in them. Wouldn't a coolant leak be in just one or two cylinders? And coolant wouldnt explain these dirty valves.
Name:	2011-02-21 18.30.01.jpg
ID:	19003   Click image for larger version
Name:	2011-02-21 18.30.36.jpg
dcraige is offline
post #10 of 13 (permalink) Old 02-22-2011, 01:44 PM
Nico's Avatar
That looks like a fuel problem... have you been trying to run it on molasses?
Nico is offline
post #11 of 13 (permalink) Old 02-23-2011, 01:48 PM Thread Starter
dcraige's Avatar
Here a pic of the back of the throttle bodies.This is only two of them but they all look the same. Very gummy with chunks of something that looks like carbon. Anyone know why this would happen? Thanks again.
Name:	2011-02-22 16.28.54.jpg
ID:	19015   Click image for larger version
Name:	2011-02-22 16.29.51.jpg
dcraige is offline
post #12 of 13 (permalink) Old 02-23-2011, 02:13 PM
Thats very dirty. Is your Air Filter ok?, Looks like Carbon with dirt on top of Pistons.
(Piranha) is offline
post #13 of 13 (permalink) Old 02-23-2011, 02:39 PM Thread Starter
dcraige's Avatar
Everything foward of the butterflys is spotlessly clean. I think the 'dirt' is flaked off carbon build up, but how? It's so much that the engine couldn't turn over.
dcraige is offline
