Bike wont get fuel or spark?? Searched but found nothing like it - 600RR.net
post #1 of 10 (permalink) Old 02-25-2011, 08:44 PM Thread Starter
ok i have a 2004 600rr i just bought. it was wrecked but it drove just fine and even started after i shut it off. 2 days passed whent to start it and it wouldnt even fire. so i sprayed in some starting fluid..nothing. so i pulled plugs and they are dry checked for spark nothing. i also dont hear the fuel pump.... i tried putting the kick stand up. put in neutral tryed out of nuetral tried holding brake tried holding clutch nothing....any help would be greatly appriciated.
muzzy12r is offline
post #2 of 10 (permalink) Old 02-25-2011, 10:09 PM
Is your kill switch set to "run" ? (We've all forgotten that at least once)
checksix is offline
post #3 of 10 (permalink) Old 02-26-2011, 06:59 PM
Nico's Avatar
Engine stop relay.
Nico is offline
post #4 of 10 (permalink) Old 02-26-2011, 10:13 PM Thread Starter
the kill switch is on. it wont turn over without it on.....what is the engine stop relay??
muzzy12r is offline
post #5 of 10 (permalink) Old 02-26-2011, 11:53 PM
Nico's Avatar
Left hand side under the ram air cover, you will find three relays, your after the one closest to your tail light.
Item number 9:
http://www.ronayers.com/Fiche/TypeID...p/WIRE_HARNESS
Nico is offline
post #6 of 10 (permalink) Old 02-27-2011, 11:41 AM Thread Starter
thanks for the info but turns out the gauge cluster plug in was a little loose and would not let the fuel pump or coils work. i found it very odd but glad i found the problem
muzzy12r is offline
post #7 of 10 (permalink) Old 02-27-2011, 11:58 AM
doofiep007's Avatar
I hope you are talking about the gray or blue quick plug on the left side of the bike....
doofiep007 is offline
post #8 of 10 (permalink) Old 02-27-2011, 12:27 PM
Interesting. Add one to the "what to do if my bike won't start" list.
checksix is offline
post #9 of 10 (permalink) Old 02-27-2011, 03:14 PM
doofiep007's Avatar
It can't start because the bas is wired through those connections
post #10 of 10 (permalink) Old 02-27-2011, 03:59 PM
Sometimes the simplest fix = the best solution... or however that saying goes.
Stevolution is offline
