From noise to oil - 600RR.net
post #1 of 16 (permalink) Old 04-30-2011, 11:31 AM Thread Starter
From noise to oil
Today I was riding my bike and I heard a old ticking since is wasn't constant I assumed it was a valve and could find a safe place to park which was justnahead well bad idea cause then the noise stopped and the bike dumped oil. I just got it home haven't started t/s yet hoping for some thoughts and ideas? I know it's not good but just looking for somewhere to start
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #2 of 16 (permalink) Old 04-30-2011, 11:33 AM
tenjin's Avatar
What exactly do you mean it "dumped oil" if you mean the bike just lost all of its oil in short order on the ground I would start looking for holes in the engine ...
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 16 (permalink) Old 04-30-2011, 11:40 AM Thread Starter
Well I can't say all the oil but quite a bit
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #4 of 16 (permalink) Old 04-30-2011, 12:08 PM
Nico's Avatar
Check to make sure you still have a sump plug, then pull the spark plugs and put her in neutral, then take the timing cover off and see if you can crank the engine over with a ratchet - hopefully it hasn't seized...
And it was a VERY good thing that you stopped... the other option was cover your rear tyre in oil and stop the painful way, and run an even higher risk of blowing your motor up.
Nico is offline
post #5 of 16 (permalink) Old 04-30-2011, 07:38 PM Thread Starter
Yeah I know it was a good thing I stopped too I am heading out to start the damage assessment but I remembered the oil was on the headers some on the upper part which should mean the blow came from top end right?
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #6 of 16 (permalink) Old 04-30-2011, 08:41 PM
nutcore's Avatar
sounds like it came from the oil filter, did it come loose? is it even there anymore?
_____________________
08 CBR600RR de-Graffiti'd
LeoVince Factory EvoII CF S/O
Protons flushmounts
tripage CA seq tail
bb led & acumen mod
ASV levers
D3 grips
Spiegler SS race lines
Puig dk smoke DB windshield
Vitamin water/poland spring frame plugs
scorpio rLink Alarm
TechSpec tank grips
Woodcraft Cut sliders
EvoTech billet front brake res
Saddlemen Tech Seat
Driven D-Axis Rearsets
Nutcore DeGraffiti'd Build
nutcore is offline
post #7 of 16 (permalink) Old 04-30-2011, 09:01 PM
Nico's Avatar
How did you go mate, just coming from the oil filter as nutcore suggested?
Nico is offline
post #8 of 16 (permalink) Old 05-03-2011, 04:21 PM Thread Starter
Things didn't go so well on the bright side when I finally got a chance to look at it the t/s was fast. In the brief moments of knock which was loud it punched a hole in my block. So now it either part out or replacement engine
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #9 of 16 (permalink) Old 05-04-2011, 04:52 AM
Nico's Avatar
That's not cool... I would go for the new engine mate.
Nico is offline
post #10 of 16 (permalink) Old 05-04-2011, 04:56 AM
DepPravacion's Avatar
hard riding, or what?
i have not heard of a bunch of people throwing rods... tough break bro.
goodluck getting her back up though,
RIP PHATTY
05/08/1980-10/19/2010
VOTE RON PAUL 2012
DepPravacion is offline
post #11 of 16 (permalink) Old 05-04-2011, 05:09 PM Thread Starter
I was riding a little hard I only crested 11k once and boom but this was a track bike for years
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #12 of 16 (permalink) Old 05-05-2011, 08:52 AM Thread Starter
Btw anyone know of engines up for sale?
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #13 of 16 (permalink) Old 05-21-2011, 05:29 AM Thread Starter
Curious anyone ever try and repair a crankcase? Now i understand if i had the chunk that came off i would be better however this isn't the option. Anyone ever try doing a repair like this where I have to create the part?
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #14 of 16 (permalink) Old 05-21-2011, 12:18 PM
Nico's Avatar
You would have a hard time doing that and maintaining the alignment of all your parts... the heat associated with welding the case will more than likely distort it enough to cause more problems later on down the track.
Nico is offline
post #15 of 16 (permalink) Old 05-22-2011, 05:07 AM Thread Starter
Yea i agree just thinking i guess i have found an engine and most likely will be buying it though it is off an 06 so like everyone else I will have the classic questions about what do i nee to swap out
2003 600RR
-asv shorty levers
-pcIII
-akrapovic slip-on
-frame sliders
-vortex rear sets
-rear cowl
Novas86 is offline
post #16 of 16 (permalink) Old 05-24-2011, 01:03 PM
Tim600RR's Avatar
Images: 16
Tough break dude. GL with it.
2003 600RR - 34,100 Miles
Tim600RR is offline
The Following User Says Thank You to Tim600RR For This Useful Post:
Novas86 (05-26-2011)
